ESTABLISHMENT OR DELETION OF CLASSES
1. At the General Rules Meeting, the membership may establish or delete a racing class. The same procedure as for rule changes will apply. In either event, a one (1) year probationary period will be in effect.
2. Special events may be added at each race at the discretion of the Race Committee.
August 5, 2012
Hello People,
The NJBA and other professional racing organization do listen to the public’s opinion weather it agrees with the existing rule or controversial opinions.
The NJBA does have the option to exercise part 2 of establishing a class based on that E85 Fuel and if there is a need to create a class that will be sustainable. Clearly the fuel is intended to reduce hydrocarbon and other negative effects to the atmosphere and is EPA friendly.
There seems to about 12-16 people who are at odds as to what class does this propellant fit!
How does this sound?
FLEX FUEL JET – E85 FJ
Blown E 85 Fuel Jets are intended to be jet boats used specifically for racing, but having highly unusual, expensive or experimental equipment.
General
1 Fuel is restricted to E-85 as intended for flex fuel. The maximum ethanol ratio to gasoline shall be 85 / 15.
Engine
1. Blowers or turbo-chargers are mandatory.
2. Maximum engine displacement is 572 cubic inches.
3. Blower belts must be Kevlar and 14mm in size.
Pressure Relief Valve Requirements
1. All Blown E-85 Jets must have a pressure relief valve attached to the intake side of the pump bowl. A pressure gage at the intake side of the impeller must be installed within 2” of the packing nut with a check ball or telltale type unit attached (0-200 lbs.).
2. A manual override button on the steering wheel is required.
3. The valve must open in an automatic fashion in case of engine failure or some other type of uncontrolled emergency.
4. The valve will be inspected at the in-ramp prior to each run.
5. Once valve is opened, it must remain open until the boat is on the trailer.
6. Piston size:
a. Minimum 4” diameter.
b. 13 sq. inches minimum unrestricted exhaust opening.
Willis
