how can i remove the stud's ine the bowl?
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
    Senior Member scottietwohoty's Avatar
    La Mirada, CA
    Default how can i remove the stud's ine the bowl?
    The stud's are frozen in the bowl.
    How can i remove them so I can put a wedge in?
    It's only as good as you make it!!
    Las Vegas, NV
    Quote Originally Posted by scottietwohoty View Post
    get yourself a stud puller....
    http://www.harborfreight.com/cpi/cta...emnumber=93132
    Man, I just double nutted mine and they came right out.
    La Mirada, CA
    tryed double nutting and it didn't work.....
    tryed triple nutting and it didn;t work....
    fock man i'm runnin out of nut!!!!
    La Mirada, CA
    has anyone used that stud remover B-4?
    I wonder if it works good?
    Southwest corner AR
    I have and they do work if they are not frost bit! Stainless or steel studs? You will have to be careful when trying to remove the studs! Alu. tends to seaze on anything! The double nut will work with some heat. Propane torch and time try going in a little and then out alittle at a time! Good pen. oil will help to! WT
    Coby
    La Mirada, CA
    Thank's I'll try that but I don't want to ruin the bowl I have a trip to laughlin on the 18th.
    Southwest corner AR
    Dont get carried away with the torch do it from the inside first then outside. Let it cool down a bit and try again (slowly!!) If it has stainless studs you might break it off, then stop on that one! Go to another one if it breaks take it to a shop or mich. shop and let them do it. They may have to drill them out! WT Just don't get to carried away with it!!
    Coby
    Senior Member widowmaker's Avatar
    San Diego, CA
    Coby
    On an old bowl with steel studs I had to cut them all flush and drill them out one by one. and then run a end tap to clean up the threads. MUST BE DONE ON A DRILL PRESS and a GOOD HOLDING FIXTURE!!! otherwise let someone do it.
    Lexington, KY
    Exclamation
    Coby
    Yes, if you are unsure about it, take it to a machine shop.There are few things that I hate more than when somebody brings in something with a bolt broken off in it, and they have tried every method they could think of, but they all failed, and fucked it up even worse. That just makes my life harder, and your's because it costs you more money/time to remove a bolt that has been seriously fucked up.
    Just my .02!
    Good luck.
    HJ
    Just my .02!
    Good luck.
    Didnt you get fired from that JOB??
  13. #12
    Senior Member cbcp's Avatar
    Carlsbad
    Get a propane torch and heat the studs up. Then double nut and remove.
  14. #13
    Lexington, KY
    Exclamation
    Quote Originally Posted by cbcp View Post
    Do not heat the studs!!!!!!!!!!!!!!
    HEAT THE ALUMINUM AROUND THE STUD!!!!!!!!!!!
    HJ
  15. #14
    Lexington, KY
    Exclamation
    Where in the hell did you get that idea?
    I never got fired from shit!!!!!
    HJ
