Oil cooler question
Results 1 to 11 of 11
Oil cooler question
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default Oil cooler question
    Anyone ever make their own ? I'm wondering out loud what's involved in building one ? Is it as simple as a tube in a tube, or more complex ? I'm thinking about making my own to fit my boat and having it painted to match.
    Swollen Member SinisterGrin's Avatar
    I guess it depends how mechanically inclined you are, here are some pics to give you an idea of whet the inside looks like
    http://www.rdent.net/gallery.htm
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I wonder how something like that would work as an intercooler?
    Wags
    Enumclaw, WA
    Quote Originally Posted by SinisterGrin View Post
    Not that mechanically inclined WOW !!!!
    Lexington, KY
    You could probably just coil up a bunch of copper tubing and put it inside a larger tube. The oil would run through the copper tubing and the larger tube would be filled with water. If you know how to weld and fabricate, I don't feel it would be too hard.
    Hope this helps.
    HJ
    Sacramento, CA, USA
    Hope this helps.
    The coil would be too restrictive.
    Wags
    Enumclaw, WA
    Hope this helps.
    Yes it does. I just was wondering what would be involved. My thinking was to make one to fit a specific location on my boat. Efficiency and flow would concern me though.
    Wet
    Wet is offline
    East Hampton, CT
    Use a heat exchanger off a 4 banger boat motor...they work very well.
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    Quote Originally Posted by DaytonaTunnel View Post
    I have an intercooler off a 2007 Seadoo RXP. Could make a tube to go around it? It's about 3 inch diameter. Heres a pic...
Name:	Seadoo parts 003.jpg
    Don't the good oil coolers have some type of thermostat?
    Lexington, KY
    Alright, how about having the oil fill the large tube and run the water through the coil.
    But, how would it be too restrictive to run the oil through the coil?
    HJ
