Aggressor Impeller Chart...?
Results 1 to 6 of 6
    The Right Coast/SE-PA
    Question Aggressor Impeller Chart...?
    Anyone have the Aggressor Imp chart, if so please post it up.
    Look here, I'm not sure if there is an Aggressor chart or not .
    http://www.performanceboats.com//showthread.php?t=372
    Sleeper CP
    Sleeper CP
    Thanks Sleeper but I recall seeing a Aggressor chart with Aggressor's name on it. I know the Berk chart is close, just wanted to have a look see at the other.
    Lexington, KY
    I plowed through every impeller chart thread on the site, and i didn't see an aggressor one, closest i found was a dominator one, and the HTP one. And i didn't see one on the aggressor site either. But im not trying to say that it doesn't exist either. But if im not mistaken, don't you just have to drop down 1 impeller size and you can use the berkeley chart and get pretty close.
    HJ
    Sometime ago I published a chart on Impellers. I lost it or it got burned up in our fire. There was a gentleman had spent some time on trying to graph our Impeller from No Cal. If I am not mistaken he did the Berkeley chart. He gave me some factor ratios for charting but said the data provided a variable to the factor. It seems the Impeller had a efficiency factor Improvment as more power was applied. I don't know if he still gets involved in the boards or not. Maybe if he see's this he will respond.
    Untill then you need to use the Berkeley Chart, just drop 1 cut to our impeller to get close. An Example: 375 HP is 4200 on our "A" I think a Berkeley "A"
    is 4600. So our "B" is there "A" Our "B" will out launch there "A". Hope this helps. Dave
    Quote Originally Posted by POPs@AggressorJets View Post
    Thanks Pops, I've been running your full uncut(A) for years now, max RPM (good cool air day 52/5300). But would it really cross over to a Berk 2-A as some suggest?
