Is that too hot for a jet boat?
Always Have Hope
I'd give my let nut to be able to maintain 180. Mine fluctuates between 150 to 170. I hope to have it worked out to where I can run a more consistant temp with my water system mods. Then I might be able to get it to run a little more temp.
Brian
Its a little on the hot side, but it also depends on how your plumbed, weather its correct or not, is the gauge working properly, what time of year is it, are you running 180 when driving or Idling thru long no-wake zones, If you want to test the gauge disconnect the wire to the sending unit on the engine turn the Ign/key to the half way position then ground out the wire to the eng. block, the temp gauge should Peg to max temp. this will tell you that the gauge is somewhat working.
Kachina Condor Tunnel hull
Hondo Hydro pickle fork, dominator pump.
Alot depends on...alot. Typically I'll see 100* swing from my oil temp to my water temp.(once warmed up)
if you ran a unrestricted water line from the jet and put a presure relief on it your temp. wouldn't change so much from idle to wot. you can check your oil temp. with a infrared gun after a hard run i don't like it to get much over 220 and 160-165 for the water be better especially if you have a engine cover . if your not having any trouble with it detonating (pinging) with 175* water you might get a little more out of it with 160*water temp. and a couple more * advancelots depends on the type of boat and engine .
Originally Posted by gn7
My understanding is, the PH 30 is the specified high performance jet boat filter.
Check the thermostat. If it has a 160 in it, switch to a 140. Remember a 160 will START to open at 160 and does not fully open until 180.
Darrell.
San Diego.
28ft Sportcat
With Twins
Not sure on the Marine Power motor. I know the ones in my Merc Racing motors are different than a standard car thermo. Check a Marine Power site for parts listings. But I have a feeling it may be the same type as a Merc unit. If you pull it, try to post a pic.
PS Btw: I run 140 thermo's in my motors, and they run at 160 in the summer.
Darrell.
San Diego.
28ft Sportcat
With Twins
it has a lot to do with flow in the system and and how much heat is being exchanged from the engine to the water , but i don't think a t-stat system with a 160* stat in it shouldn't go over 165* if it's working properly and there's nothing wrong with the engine. MAXXJETT do you have a pressure relief or a restriction on your water line from the jet ? i don't think your getting enough flow especially at low rpm from a restrictor or valve at the jet???
