What size bolts should be used when attaching the rails and plates to the stringers?
Was thinking of going 1/2, but couldn't find any of the big marine parts dealers selling anything longer than 3 inches?
Maybe 1/2" is overkill ?
A good rail kit is always approx. 30" long & longer in some cases, with that kind of distributed mounting points 3/8" works fine, you could get away with 3 per each side,We alway use 3/8" Coarse or Fine & use Nylock nuts, stainless is a must, If the rail kit has a Flat strap of alum. that goes on the outside of the stringer it's not necessary to use stringer washers otherwise definately use stringer washers.
Kachina Condor Tunnel hull
Hondo Hydro pickle fork, dominator pump.
Rex Marine Home
Rex Marine Shopping
Mike
909-592-1000
See my photo gallery at mikegeephotos.com
A tribute to the victims of 911 - Never Forget!A Tribute to our Troops (Remember Me)
Please Spay & Neuter your Pets (a video)Please adopt and learn about the huge problem of overpopulation (a video)
Please Feed a Shelter Dog (It's Free) - Your clicks can mean the difference between life and death.<<<![]()
“He who is cruel to animals becomes hard also in his dealings with men. We can judge the heart of a man by his treatment of animals.” Immanuel Kant
I'm sorry I would need a more specific description, not familiar with NJBA requirement specifically. Would need size and material needed specs... Personally I would be running stainless on an intake unless they were the equivilent of ARP 300 stainless in strength (I'm not aware of ARP's in a flat head socket config). Otherwise it would be grade 8 steel at a minimum for me.
Rex Marine Home
Rex Marine Shopping
Mike
909-592-1000
Recently I read on this forum that grade 8 bolts (only) should be used on intake grates/loaders and to not use stainless bolts.
3/8 bolts will work fine, If you are going to use stainless make sure to use anti-seize on the threads. I would space the bolts 6-8 inches on center and try to stagger them if you can so they are not in a straight line. Good luck with your install.
Ironman
X2 re the stainless for the rails to stringers , Rod re the Loaders ,heres how ours go out Grade 8 o'size & (with bottom trim/install intructions) Tom
ditto! 3/8 bolts are fine! with the distribution of weight and torque factor involved good to go! Just do me and your'e self a favor, if you are drilling into virgin wood use a sealer to protect for water penatration into the stringers! Water will find any way to get absorbed into wood and add weight and wood rot that doesn't show till it's to late. If it is a fresh build and may get moved for a correction then fill the drilled holes with silicone and coat the bolts then install. If it is a one shot deal then drill and seal with resin and STILL silicone bolts for installation. better safe than sorry! Also if you choose stainless please use anti-sieze on the threads for later removal for any reason, Stainless tends to thread bind and I have found the a dab of anti-sieze works wonders! IMLAO M
