Oil relocation kit
Results 1 to 6 of 6
Oil relocation kit
    Senior Member Rain Maker MN's Avatar
    Default Oil relocation kit
    Was wondering how many people are running an oil filter relocation kit?
    Does it help cool the oil quite a bit?
    I am going to be running a HV oil pump....but it just seems like a long way to push the oil through possibly 2 filters and back to the engine?
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Quote Originally Posted by Rain Maker MN View Post
    Little effect if any on temperature. Mostly for convienience in changing filters. #12 lines you will not have any problems.
    Costa Mesa, CA
    You need to purchase a 2" oil cooler from Rex Marine.....right Mike?
    2002 Ultra 21 XS
    2000 Ultra 19 Shadow
    Blog Entries
    24
    Well, that is what oil coolers do...
    However #1 is to determine if you need one (with an oil temp gauge). Too cold of oil is not a good thing. I like 220-230ºF range for good quality oil for proper lubrication and moisture burn off. If one is pushing 240-250+ range then it is time for a cooler.
    If the oil temp is between 220-230 degrees, what would the water temp be?
    Always Have Hope
    Senior Member bead's Avatar
    Default here's mine
    w/ an oil cooler
Name:	454  motor      110.jpg
