cuttin headers
Page 1 of 3 123 LastLast
Results 1 to 14 of 31
cuttin headers
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default cuttin headers
    Any of you cut the flare or shorten your chrome headers... What'd you use or what did the shop use? A local shop said they can use there cold saw but they arnt sure how the ends with the chrome are going to look. i was the cut clean, and dont want the chrome to be all retarded and jagged.
    Where the chrome is cut, it will most likely chip or peel.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Senior Member ULTRA 23's Avatar
    Corona, CA
    Chop saw
    John D
    INLAND ULTRA CUSTOM BOATS
    Corona, CA
    951-734-6000
    Ultraboats.com
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    Quote Originally Posted by DMOORE View Post
    Darrell.
    yeah it will, but mine didnt too bad, maybe a 1/16 of an inch or so.. looked a helluva lot better than the length they were before
    "i'm into snatchin' kisses... and vice-versa!" haha
    Senior Member cbcp's Avatar
    Carlsbad
    Chop saw, then have them coated. Have done 3 pair this way and all of them came out bitchen.
    Senior Member widowmaker's Avatar
    San Diego, CA
    Quote Originally Posted by ULTRA 23 View Post
    Chop saw
    crude
    or make friends with someone who has one of these
    UMPBA.ORG sleekcrafter's Avatar
    If you want your chrome to look decent, You need to scribe a line around the tube, this needs to be through the chrome. Then cut out side of the line a little, and then final trim with your choice file or grinder. But please note work in or down towards the chrome, or the edge will lift. Scribing gives the chrome a place to clean break after the cutting process.
    Las Vegas, NV
    i seen it done with a chain saw
    When I did mine, I used a sawzall with a fine wide/ long metal blade (The Torch) and taped around the header to get a good line around it I have seen some that will use silver header paint at the end to protect against rust.
    Vinyl Graphics, Magnetic signs, Reg #s, Boat names, Banners, Boat decals, Etc. Please contact me Via facebook or e-mail cycodesigns@hotmail.com.
    Senior Member W.O.T's Avatar
    Campo Ca
    Chop saw then clean them up a little. No chipping on my chrome headers.
    Silverdale, Washington
    When I was cutting mine I couldn't figure out the best way to make a straight line around the pipe.
    Then my punk ass kid walks out and grabs an old piston ring compressor we used for his motocross bike and slid that on. With a fine tooth hacksaw blade and the compressor serving as a guide, he nailed it.
    He then just clamped a straight edge on it and moved the compressor over to the other pipe. Slick as a whistle and no chipping of the chrome.
    I'd still be trying to figure it out if it was me
  13. #12
    Senior Member wetdebt's Avatar
    OCALA,FL
    This may be & most likely is a dumb question why do you guys cut them any way???
  14. #13
    Cylinder head offset. I use a tubing cutter, perfectly straight cut with no chrome damage. Leaves a inside burr that is removed with a pipe reamer.
  15. #14
    Senior Member If Looks Could Kill's Avatar
    Sep 2008
    Upland
    I put duct tape around header,marked with sharpie and cut with sawzall,
    measured from the collector weld back
