place diverter questions
Results 1 to 6 of 6
    Senior Member Factory502's Avatar
    Default place diverter questions
    I have an older model place diverter (Pre ride plate/FTN casting), the ones that have the downward facing outlet below the reverse bucket- anyway, is there a justifyable enough performance diferance to upgrade to a new model with the tuneable nozzles? not racing this thing, just trying to build a respectable river boat-
    Quote Originally Posted by Factory502 View Post
    Fact' if your trying to "squeeeze" the boat for every last drop of Performance yes if not that original style/design (second generation,I belive) diverter works very quite well , Son Josh just re-engineered that piece and swaped it out for his newer "ride plate stlye" this past month we will now produce this from that older stlye with butt bucket if anyone wants one Tom
    before
    now
    Thanks Tom- Is that "butt bucket" the original set up, the diverter I have has the newer style bucket, just no ride plate casting- Which leads me to my next question- can the nozzle I have be bored for adjustable nozzle- thanks again
    Bo
    TEN THIRTY ONE RCB19's Avatar
    Bo
    You can machine down that older style reverse chute to be flush with the bottom of the round nozzle. This will reduce chances of drag. Yes the nozzle can be bored for inserts.
    RCB
    Thanks RCB- that is what I needed to know-
    As RCB said that older PD has been bored for a choke and the machined and filled to "close" off the reverse chute Tom
