Originally Posted by
SmokinLowriderSS
Fo, where are you drawing 12vdc power from to operate the solenoids?
Do NOT pull it from teh power feed to the ignition coil.
If you have a short, it'll drop violtage to the coil and kill the engine.
Some of those solenoids draw a fair bit of amperage when triggered, and can again, drop voltage to the coil and kill the ignition.
Insufficient fuel flow will NOT just "turn off" the engine, it will starve it over several secconds to kill it. You are, for some reason, loosing power to the ignition when you trigger it.
OK, now, wait a seccond, you need 2 switches, are you running both?
They are in series so BOTH must be pressed to "fire" the system. This is precisely so that you CANNOT inject nitrous at any setting below full-throttle.
With the WOT switch "open", the arming switch does NOTHING except provide power to the contacts of the WOT switch.
You can drive arround, all day long, bottle open, arming switch on, cruise all you want, and never use a drop of nitrous, as long as you never floor the throttle.
At idle, or even a fast idle, any setting below the wide-open-stop, the WOT switch will be open and the arming switch will have no effect on anything.
If it does, something is mis-wired, or shorted.
U
Now, if for some silly-assed reason you have the WOT switch depressed at idle, and trigger the arming switch, you flood the engine with fuel, and kill it.
If you ever do the above with the bottle open, you are very likely to break things, expensive things.
