I have a stiff steering cable. How can I take the cable out and lube it? I have a Teleflex NFB rack and pinon steering system and a legend jet pump. I don't think that I should have to get a new cable if the one I have only needs some grease.
Buy a new cable, your wasting your time.IMO. Good luck.
Unlike some things once those things get stiff Once the cable gets that way its pretty much done, my pops once spent days hanging one from close line and lubeing it with WD , New rack systems are relatively inexpensive and simple to installTom
Always check your "steer tube" for adjustment , the tendancy is to overtighten the bushing nuts and the steer tube must move ever so slightly back and forth to compensate for the swing of the tiller ,If the tube is too tight it will cause the steering to bind and be stiff, A good working rack should be "pinky finger operation" out of the water, Also having a swivel clevis (about 20 bucks)at the end of the rack shaft helps alotTom
Ok Tom I will admit it I have no clue. Where do I adjust the steering tube? I have a U clamp that the cable jacket clamps to the jetovator cable mount
I have always lubed my cables. In fact I did that to my current boat, you couldn`t turn the wheel when I got it. The trick is more power. If you let gravity do the work there is not much chance of it working....however, if you get a piece of clear hose, clamp it on over the end, (after you loosened the inner guide, sorry I don`t have a cable nearby so no pics) then you fill the hose with some w-d40. Now for the important part.....put a quick disconnect on the other end of the hose and hook it to the aircompressor
. After you force some wd40 through you can move to heavier trans fluid or whatever the oil of your choice is.
10' Custom with 25 Merc_____17' Sleekcraft jet____85 El Camino SS 5.3L/4l60E 3.73 posi____1980 Chevette 4.3L v6/4l60e____www.fquick.com/G-Body
Like this?
I tried this too. and it worked grate. After a few months the cable did start to get stiff again. I left the hose connected with WD 40 in side the tube for a weekend with the pressure set at 15lbs.
Takin it home
If you know it's going bad , plan on replacing it....cause it's gonna bite you when you least expect it. Being unable to make your trip, or unable to steer your boat, both unacceptable scenarios IMO
I saw replacement cables from 99 - 140 bucks. I would not even worry about lubing that sucker and just replace it. Not worth it getting stuck while on the water. Looks like tommy has a few sittin around just call him and get one shipped to you.. I cant imagine it would be difficult to replace.
Just change the cable . I had one break on me , thank god I was going slow. That could have been very bad![]()
Spider Monkey Racing
FRIENDS DONT LET FRIENDS DRIVE EGGBEATERS
