Impeller repair
Page 1 of 2 12 LastLast
Results 1 to 14 of 25
Impeller repair
    Monroe, WA
    Default Impeller repair
    How much straightening can you do on an aluminum impeller? I've got a spare that I need to use but it has some bending on the exit blades. Just wondering how crazy a guy can get with some heat and straighten them back out?
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Malcom we dont recommend this on Alum alloys (welding or straightening) for a multitude of reasons , much prefer to "help" you on a new or solid used one than see a repair are we talking WJ? if so we got some new things for that pump that might interest you (protos this week ) Tom
    Jet boat service
    Sebastopol Cal.
    Malcolm, I wouldn't be using heat to straighten out those blades. Aluminum impellers are heat treated and you will cause more harm than good in my opinion. I would also check the raidial diameter of the wear ring skirt. You should be in the neigborhood of 7.225. If you are down to 7.220 I would suggest an oversized ring. I also evaluate the vanes where they intersect with the hub, if they are thin and very worn inward I chuck them into the aluminum pile. Jim www.performancejet.com
    Monroe, WA
    This is in the new ride, Tom. I pulled it apart last night and found this...
    I have this other pump I was thinking of swiping the impeller if it was fixable. Two of the blades are like new, then one has this...
    Then just a little one on the 4th...
    I think I'll just yank them both and head for Skagen's.
    Malcolm
    75 Spectra 18
    Ouch ! Thats some pretty serious rock action !
    alum impellors are cheap, buy a new 1. you straighten that vein out and its just gonna snap off that much faster.
    Monroe, WA
    Yeah, they always seem to bend easy one way, but not back.
    Yeah, this rock is a monster! It's been in there since before I got it. I wondered why it was so slow. It's best speed was 48 at 5 grand.
    Malcolm
    75 Spectra 18
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by Malcolm View Post
    sounds like a Panther...............
    I have a basically new American Turbine AB (abut 30 hrs runtime), I have pictures if you're interested.
    Silverdale, Washington
    Will a American Turbine impeller work in this pump? If so, I think I know where there is one with less than 10 hours on it that's available. The current owner is a REAL good guy (and damn good looking too).....
    Speakin of which Give me a call "handsom" I got your D/L delima handled T
    Will do Cupcake.
    Malcolm give me a call or send me an email...
    Here you go Malcolm. It's sitting here waiting for you and you can tell that it has less than 10 hours on it.
    Now that I see how nice it is, I'm not gonna take a penny less than what we have agreed upon already!!!!
    Tommy, got the DL too. Thanks a bunch and let me know what I owe you...
    Frozen Tundra, WI
    Is your intake grate missing??
    I have never seen a pump suck up a rock that big with a grate on. , WOW
    Prune-Picker
    Calif
    Just curious. Why are there no threads showing through your impeller nut?
    Cs
