Marine grade carpet - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 22 of 22
Marine grade carpet
  1. #15
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Whatever you guys do, go with the 40 oz. marine carpet like the stuff that Rex sells, its a little more cash, but what you end up with is far better than a 30-20 oz. carpet! feels great on the feet, more durable, does not stain lighter colored towels or clothes when wet on the floor of the boat!
    one more thing, 40 oz. carpet hides a tone of imperfections in the floor of your boat, it has got to be the easiest carpet to lay down and tuck into the corners of a stringer and/or bulk head! just my .02
    Todd
    riverside brawny's Avatar
    Default go with the 40 oz. marine carpet
    i agree the 40 in our boat has held up really well since
    it was installed 4 yrs. ago.
  4. #17
    Senior Member wpy3's Avatar
    Pittsburgh, PA
    Next time try R-M "PreKleeno". Soak a 2x3 towel, rub the area with it then lay the towel out over an area. After about 5 min it will scrape off very easy. This is what the body shops use.
    Quote Originally Posted by Brad @ SCJB View Post
    i used the homedepot stuff in my liberty and had to pull it out...it was a disaster...the fibers pulled through the backing when i pulled it up leaving a ton of chia pet fuzz all over the floor....it was a long long tough project to get it all out with a scraper and lots of gasoline and trying various solvents to remove it.
    the stuff is cheaply put together and unwravles when you cut it. it doesnt leave very clean edges.
    Las Vegas, NV
    Quote Originally Posted by wpy3 View Post
    thanks for the tip. i will give it a shot next time.
  7. #19
    TRG
    TRG is offline
    Quote Originally Posted by brawny View Post
    ...that would be 7 year old carpet if this post was meant about my old boat.
    and it is the same dark charcoal that Rex sells.
    I personally would recommend a sprayable yellow glue that is a "Dap" product (Found at most all interior supply houses), stay away from water born glues as well, water and fuels will delaminate your carpet faster than you can pound a beer in a desert hot spell! just a few more cents on mine that have worked well for me in the past!
  8. #20
    Member pushingvws's Avatar
    auburn, ca
    Cabelas.com or westmarine.com
    good selections
  9. #21
    Las Vegas, Nv
    I called Santa Barbra Upholstery Today. The Guy that I talked to said that They had the Marine grade carpet , but only carried the 20oz, and it is $32 per yrd and comes in 6' and 8' widths. I would need an 8'x 12' piece or 4 yrds, and would cost $128 + tax, which I guess is not a bad price ,but its not the 40 oz. He said He carries 4 different shades of blue, so I am going to go look see at what They have on Thursday.
    Rex, Is Your carpet 40oz or 20 oz, and what is it per yrd....Hal
  10. #22
    Las Vegas, NV
    just to give you a heads up.....he only has brown, grey and back in the 8' rolls.
    the larger selection of colors in the 6' rolls.
