waxed half the boat...
Results 1 to 13 of 13
    OXYMETHOLONE 50 DEMOLITIONIST's Avatar
    Apr 2009
    Default waxed half the boat...
    need to get the other half done!
    i used this FW-1 spray and wipe crap, worked pretty well. you can see all the crap left on the left side by only washing it. not perfect, but the whole right side turned out better than i hoped!
    im NEW... be patient...
    Southwest corner AR
    If you used a buffer that thing would POP! Looks good! WT
    WT
    WFL Crew!!!
    Is it Summer Yet?! SoCalKev's Avatar
    Santa Rosa
    Nice Miller!
    Agreed: USE A BUFFER!!!!!
    Sanger Super jet in Progress
    two strokes is enough dp85tona's Avatar
    Yuma, Az
    Meguiars two in one abrasive/ polishing compound with meguiars wax with a variable speed buffer its worth the work.
    1995 Summerford STV Euro
    Quote Originally Posted by dp85tona View Post
    X2 look on ebay and get the mequiars gelcoat restoration kit, it comes with the compound, polish and gel wax for 35bucks. it kept my tx19 looking great and it was alottttt worse than your boat. when your doin quik clean up at the ramp after a day out, get some original pledge and wipe the boat down with it. it puts oil back in the gel , plus pledge is a wax.
    s480@18lbs nto 325cubes of whoopass : ) turbo boyz
    Apr 2009
    my dad does mobile detailing on cars, i think he gets stuff direct through meguiars. i'm going to have to ask him to pick some up!
    thanks!!!
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    Nice boat B
    Senior Member brgrcru's Avatar
    Montrose
    Looks good,your 1/2 way there. Now get to work
    Senior Member coonass's Avatar
    Have No Idea
    Quote Originally Posted by brgrcru View Post
    No keep it like that and call it TWO FACED!
    Looks great
    Broken Arrow, OK
    Quote Originally Posted by coonass View Post
    Looks great
    nice...
    The Right Coast/SE-PA
    Looks good however...in time it could be a chore keeping up with the gloss. When I purchased my 21 Daytona I wet sanded it and machine buffed it >looked great!
    In short time I was fighting holding back the oxidation again, especially where water would wash away the daily polish/wax I put on it.
    Having enough I decided to sand the whole boat(top and sides with 600 and put a clear coat over everything. True the clear coat will chip easier(I'm more careful) however the gloss is always wet looking and it's super easy to take care of.
    Below is before buffing
  13. #12
    Member aj06bolt12r's Avatar
    Feb 2010
    Middle Tennessee
    So you just used regular automotive clear coat? Looks great!
  14. #13
    Senior Member sanger448's Avatar
    Apr 2009
    Medford, OR
    Default Turtle Wax
    Does it get any better than this $5 wax job?
