So my new trim switch works awesome and is super responsive. The new gauge is also responsive but takes a 2 count to start moving. Could too thin of a sender wire cause the issue? or could my sending unit be acting up?
are you talking about a trim gauge on a diverter?
#55
Get a heavier wire connect it up and just lay it loose over the seats etc. as a test. If it's still slow you'll have your answer.
We'll do this all the time in the electronics business. Many times it's faster than ohming things out or trying to do calculations. Quick n easy......down n dirty.
Mine had a "lag" in it. Had to use a stiffer inner cable cable.
Loose, the Dogs of War!
another pict.
The inner cable would bow then flex and deflect the lever on the transducer.
Good luck.
I went to a bicycle brake cable to remedy the problem.
Delemorte,
If you're talking to me, great!
I really enjoy having the feed back on nozzle angle. It makes my trimming repeatable. I've found the sweet spot.
