trailer hubs
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
trailer hubs
    blown mopar moparjet's Avatar
    manassas,va
    Default trailer hubs
    what is the standard bearing size and the best place to buy 4 new trailer hubs? mine are done.. axles seem to be ok. what is the standard bolt spacing for 5 lug? thanks for any imput
    throw it in reverse
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by moparjet View Post
    You can get a hub kit. Comes with the bearings. Bolt pattern is 5 x 4 1/2
    Charlotte, NC.
    From my experience there is no standard bearing size. You need to pull your bearings and either measure the ID or get the numbers off of them.
    This is where i bought my new axle hubs and bearings.
    http://www.redtrailers.com/
    My experience.
    http://www.performanceboats.com//showthread.php?t=17759
    You can find all my pics in here.
    http://s438.photobucket.com/albums/q...view=slideshow
    manassas,va
    i want to say they a inch and 1/16.. but not sure
    throw it in reverse
    Charlotte, NC.
    Are they both that size? Tapered non tapered? You also need to know if your bolt pattern is 4 or 5 and if its 4 or 4.5 inches. and your hub length..
    http://www.redtrailers.com/ListItems.asp?cat=16
    Also do your self a favor and invest in some bearing buddies. Cheap insurance.
    http://www.redtrailers.com/ShowItem.asp?id=2047
    Cas
    Cas is offline
    Angry American Cas's Avatar
    since you pulled it apart, you should be able to get the number right off the old bearings, races and seals. Once you get those numbers, you should be able to get them at a Napa Auto parts store.
    High Rock Lake, N.C.
    You replacing those bearings to come to High Rock or you "wussin" out again?
    Las Vegas, NV
    it all depends on your axle.....
    i got my set from bearingbuddy.com ... http://www.bearingbuddy.com/orderhk.htm
    depending on your axle....its about $60 per axle and comes with all the races and bearings you need...plus buddys!
    Charlotte, NC.
    Quote Originally Posted by Brad @ SCJB View Post
    Those dont include grease seals do they? Wont he also need to know the OD of his axle so the seals ride properly?
    I went thru all of that and ended up buyinga new axle.. Then again my spindles took some damage...
    Las Vegas, NV
    Kits include: Studded hub with two pressed on race (cups),
    bearings, cutter pin, lug nuts, grease seal,
    and Genuine Bearing Buddy® Model 1980.
    it comes with everything you need. just take off your old hubs...look at your bearing numbers....match them to the kit you need....measure your spindle with a caliper for good measure.
    Las Vegas, NV
    heres a thread where i started posting information on how to do this...
    http://www.socaljetboats.com/index.php?topic=5360.0
    everything is posted except re-assembly
  13. #12
    manassas,va
    thanks for the imput guys..
    throw it in reverse
  14. #13
    Charlotte, NC.
    Good thread..
  15. #14
    Don't forget to put green grease in them new hubs, it is good stuff!
    http://www.greengrease.net/
