anybody have any pics of a fully functional jetovator setup?
I think I have all the right pieces to it but want to make sure-cant figure out how to attach a cable to articulate up/down.
as I recall it works just like the deverter Brian![]()
Go on get your ass outa here
The up down portion hook up is different.
See pic below- up down portion does not appear to be operational. Needs a cable on it, but how/where does it attach?
you know the more I look at it,it looks like a manual adjustment,and not adjustable on the go, by turning the mount on the steering tube in or out to get a different angle! by removing the bolt form the peice on the noozle and turning the mount,and the reattaching the mount! just a guess!
I know they are adjustable...Just not sure how the other cable hooks up.
Nevermind. Figured it out. There are more pieces that mount on the inside of the boat that allow adjustment under way.
Looks like you got it hooked up right. Steering to the tiller. Jetovator to the bracket. Now the fun part of dialing it in.
Do you have a pic of the set up from directly behind the pump?
Takin it home
Here's the inside of what mine use to look like. But by now you've got it figured out.
Wags
