Thanks guys.
Mike that's the way I wanted to do it, and will. I need to pick up the proper fittings etc. The only reason I ran the capillary is because everything I needed was in the kit for a quick and easy diagnostics check. Also cut the tubing down to 2' (just long enough so I could put the gauge up front and watch it from the seat for the test.
Hopefully that's all it is and I can nurse another season out of it. I believe I'll try to rest my foot on the gas pedal just a bit lighter though........![]()
LinkBack URL
About LinkBacks
#55
