angry big block
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 53
angry big block
    Feb 2009
    Hemet, Ca
    Question angry big block
    my friend has a carribean 19' with a 454 bb and jacuzzi. motor is mostly stock with a mild cam. we broke in the cam at 2200 rpm and then took it 4 a test run at lake elsinore. made it 3 laps around before it started backfireing out of the carb and losing rpm n power. we replaced the gm hei cap and rotor for a tried and true accel cap, coil, and rotor. when we launched at the river(lost lake) it ran great for a half mile up river before the same problem returned. by the way, he is not much of a lead foot, more of a cruising guy. i appreciate any help.
    I'd pull the rocker covers and crank the motor to observe valvle /pushrod/rockercam action call if we can give you tech help Tom
    Feb 2009
    Hemet, Ca
    lookin for a flat cam basically?
    Redding, CA
    Your cam has flat lobes. hate to say it.
    You will find loose rockers and flat lobes.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Quote Originally Posted by E-ROC View Post
    What's the status of the fuel filter? Been checked or changed recently or with the new engine?
    The fact that you stated it ran well both times before having the problem leads me to believe it's not a valve train problem, but certainly check that out to make sure.
    Feb 2009
    Hemet, Ca
    brand new fuel filter, fuel/water seperator, put on motor before the test run. by the way, whats the best method for checking for a flat cam?
    Feb 2009
    Hemet, Ca
    i just checked with him and he said that all but the wiring is new. we did however go thru the wiring just to double check and it all seems to be savy.
    If you are sure the carb is not starving for fuel, you can pull valve covers and check the valve lash. If you have one or more that are way loose, and the polylocks didn't just back off or something, that would indicated a cam lobe went away.
    Vacaville,Ca.
    Does it clear out after it sits a few minutes.. If so it may be a venting problem.. Or a collapsing fuel line!
    Feb 2009
    Hemet, Ca
    we did let it sit and cool 4 a bit before returning to the trailer and it didnt make a difference, but i will confer with him to make sure since i wasnt 100% sober at the time. im trying to get him on here to help with the tech. give me a few and i will get back with you all. by the way, thanks for the help so far!
    Senior Member cave's Avatar
    Mesa, AZ
    Did it run good before you changed the HEI to Accel?
    Water in your fuel could also make this happen. Idles great then sputters at the top.
    In the Kachina I have I get a fair amount of water in the tanks just plowing through the wakes. I ed to stop & drain the separator a few time a day to keep from sputtering.
    Takin it home
    Feb 2009
    Hemet, Ca
    thank's for you help guys my name is john and i'm the owner of the angry big block. the only info e-roc forgot was that the day we took it for it'stest run the valves were too tight and no oil got to the upper valve trian. after fixing that it seemed to run great out of the water but the morning it went back in it only ran for about a mile and it wouldn't pull above 4200 rpm with my foot to the floor. the motor setup is 9:1 compresion rv cam performer intake holly 650 vacume secondary carb with wet log exhaust.
    Feb 2009
    Hemet, Ca
    it wans't in the water long enuff total run time was under 5 min on glassy water
    Feb 2009
    Hemet, Ca
    wheres the winded walrus??????????
