TX 19 youngblood - Page 6
Page 6 of 11 FirstFirst ... 3456789 ... LastLast
Results 71 to 84 of 154
TX 19 youngblood
  1. #71
    Southwest corner AR
    Quote Originally Posted by Just Electric View Post
    that seems to sound alot better on the numbers there brian
    Yes, it sounds much better! And did you do 82 with a high rooster tail?? WT
    WT
    WFL Crew!!!
    Senior Member Boost's Avatar
    Pomona ca
    Somebody got jokes no I made my pass with it down.
  4. #73
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    Default motor placement
    Leave the motor where it is!! you will spank all your friends on take off and it wont speed up a bit with an H-joint but will make the boat stand up on take off. (wasted power!! and lost et.) I have set em up with longer shaft than that. Rember drag racing is about getting to the finish line first!! I agree with the thru bolting of the loader, that is a safety issue. That can cause you to get wet. Good luck with the 'blood you can see all our gang at www.youngbloodjetboats.com you can see mine by clicking on "hottest jetboat" If you have any questions you can e-mail me at 2badbloods@att.net
    Keith
    Senior Member kdub's Avatar
    Houston
    My motor is up that far ( 26" from transom to rear motor plate ) and I still blow up on the hole shot, full set back Dominator, Berk droop, MPD prepped B/C Berk impeller. Boat jumps completely out of the water and unhooks the pump and it cost me a rod bearing when it stretched the bolts on #5 ( pretty sure that was it ) was wondering if anybody was having this issue and if so are any of you guys using HTP snoots instead of standard droops ( no diverter )?
  7. #75
    Pomona ca
    Default Out the hole
    When i flat foot the boat out the hole no bow up over here it gets and goes thats with the diverter in the down position, how do most of you guys lunch your boat? I usually make a pass to set the diverter.
  8. #76
    Feb 2009
    East Texas
    For me I leave with it on the wood sprayin it from a dead stop with no place diverter and it hooks up an goes. It is worth the timeand work it takes to move the weight around in the boat to get it just right. Placement of the motor is the largest, but you have other stuff too, fuel, battery, nos bottles etc.
  9. #77
    Houston
    Had it leaving perfect till I put the MPD impeller in it and now it hooks so hard that the boat jumps out of the water when I am by myself, if I add the weight of a passenger it stays down.
  10. #78
    Breathing Diesel Shotgun19's Avatar
    Michigan
    My hand hole is outside the hull and the boat leaves hard with no cavitation. Still playing with it just not sure how far to push it. Spins an A impeller 7200 rpm no problem and has more to go. Depending on the economy next year it might be at the track to play
  11. #79
    Houston
    I dont have any cavitation at all the boat just jumps out of the water and unhooks the pump because the intake leaves the water at least partially but some say completely. One passenger and it is fine and leaves super hard, i just have to tune for the weight reduction I guess and get the bow down to keep it in the water
  12. #80
    Feb 2009
    East Texas
    Quote Originally Posted by kdub View Post
    Sounds like you need to give it more power on takeoff to let the pump slip a bit. This will help it leave on a set w/o standing up.
  13. #81
    Feb 2009
    East Texas
    I run a straight nozzle, but I have a tunnel with 899hp on motor and another 350hp shot on the juice. Give Duane at Hi-tech performance a call and he can tell you if it is right for your app. They have sped up every boat that we put em on.
  14. #82
    Feb 2009
    East Texas
    Quote Originally Posted by Shotgun19 View Post
    How much power??
  15. #83
    Houston
    should i try to leave on the nitrous to get it to set better? I thought more power would make the problem worse
  16. #84
    as soon as you hear the pump load, you should be on the nitrous
