TX 19 youngblood
Page 1 of 11 1234 ... LastLast
Results 1 to 14 of 154
TX 19 youngblood
    Senior Member Boost's Avatar
    Pomona ca
    Default TX 19 youngblood
    Well after eight are so v hulls I finally step up to a gullwing its a light layup set back pump motor moved forward 502 BBC merlin heads no gps yet hoping for high 70's It runs hard so i haven't touch the motor are tuned it,going to re rig it this winter.
ID:	47289   Click image for larger version.
ID:	47290   Click image for larger version.
ID:	47291   Click image for larger version.
    Senior Member s2k1's Avatar
    Sounds like fun.
    Chris @ Benchmark Performance
    Colfax, Ca
    They are fun boats!! I have a TX-19 Condor. Great rides and lot of potential.
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    Quote Originally Posted by Boost View Post
    im freaking jealous, thats a bad lookin ride mang!
    "i'm into snatchin' kisses... and vice-versa!" haha
    El Cajon, CA.
    Default Congrats!
    How heavy is your boat's hull? (Edit = it's a light lay up. Mines light also. 450 lbs with intake and loader.)
    Q.C./Big River
    Congrats! You're gonna love it!
    Pomona ca
    Default Thanks guys
    What kind of MPH should I expected just under 600HP and it has a tight pump, loader.shoe. ride plate, insert
    Senior Member elponcho's Avatar
    Sweet..... I want to play with my current boat over the winter. Then either find a Youngblood project to restore or buy new stage 1 and rig it up.
    Senior Member brgrcru's Avatar
    Montrose
    With not all the info, my guess would be 80 -85mph.
    Q.C./Big River
    Quote Originally Posted by brgrcru View Post
    Sounds about right. I have about 500 hp and I am running 80 but I have a dialed pump and setup. If I had 600 hp I would probably see 85 or better. Good luck with it. You are gonna love it.
    Pomona ca
    Default Tx 19
    With the motor move forward am I gaining performance are losing do to HP I'm guessing someone had some big HP in their at one time.
    Glendale Arizona
    Also possible that they were running a jetaway. I've got one one on mine and the motor sits 7 1/4" forward of where it was without it.
    On a good day with the stars aligned my 19 would run 80 mph on the motor (500 hp) and 87mph with a 150 shot.
    Q.C./Big River
    I do know that there must be the proper balance in the boat depending on what you are running it for (race/river). If you really want to air it out then you want the seats and the motor as far back as possible, but don't go too far. This is one of the reasons to set back the pump (there are a few other reasons). Your motor may be in the optimum position for your setup or if it had more power when it was setup then it might be hindering you. If you aren't going to race it then I wouldn't worry too much about where it is exactly. I know I could do a lot to get more out of mine but it would also cost a lot more for exactly how much gain??? the only way to find out is to move the motor back, if you have the ability and resources, and run it to see if yo improve. Have fun, there are so many things that can be done to these boats to improve performance that you could go crazy and broke looking for the magical sweet spot.
    Pomona ca
    Default Drive shaft
    This might help 18'' drive shaft no extra holes in the stringers must of been rigged like this since day one.
