Anyone have the Distributor wiring diagram/ firing order for a 1970 455 Olds - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 15 to 28 of 30
  1. #15
    yeah I know how to "find " One by turning and what not, the engines never been messed with or removed it's all stock so I wanted to find it without having to turn anything
    Olympia, Washington
    Just trying to help, good luck.
  4. #17
    Cas
    Cas is offline
    Angry American Cas's Avatar
    here ya go-
    Counter clockwise 1-8-4-3-6-5-7-2
    Thanks steve !, and It's ok just a miscommunication, appreciate the quick reply
  7. #19
    oldslomobile bad muchacho's Avatar
    Yuma AZ
    Thats not where mine is at but i'd trust that pic for stock. I may have put mine in in the wrong place. like said earlier it dosn't mater where it is if the order and rotation is correct.
  8. #20
    would it still bet he same even though mine only has two screws on the distributor cap, cause your diagram shows four.
  9. #21
    Yuma AZ
    thats an HEI diagram off of a 75 or newer. but it should still be the same i would think.
  10. #22
    Olympia, Washington
    Don't mean to be an ass but you could have pulled the plug and found # 1 by now!
  11. #23
    Cas
    Cas is offline
    Quote Originally Posted by OldGuywtihanOlds View Post
    the distributor in the picture depicts an HEI is the only difference. You can just pretend 2 of the screws aren't there for the stock point distributor.
    It actually does not matter which contact on the cap you use as #1 providing the distributor is set in with the rotor coinciding with that particular contact and the #1 piston is at TDC.
    I hope that made sense.
  12. #24
    It does Thanks again !
  13. #25
    Monroe, WA
    So is it running yet?
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
  14. #26
    Alamogordo NM
    Default I remember that
    I went through this deal not long ago, Just crank the motor over with a 1 1/8'' socket and breaker bar with thumb on spark plug hole. When air pushes past your thumb that is the compression stroke. you cant always trust the mark on the balancer. As soon as the air stops pushing you are at top dead center #1. The mark on the balancer should line up with the zero on timing indicatior. Now where the rotor is pointing on the dizzy is the #1 cylinder. when I figured it all out I made a modification to the diagram shown earlier to make it reflect my exact setup. My #1 is located at 1 o'clock looking from back of motor. I suggest you do this, print it out, put clear tape on it and keep it out in the shop or garage for future reference for when you f up and remove too many plug wires at once. Of course I am a self proclaimed numbskull so I keep stuff like this around.
Name:	olds firing order.jpg
  15. #27
    Mar 2014
    Default gm distributor for marine
    i have a gm distributor for a marine 350 model#480151 , anybody have any knowledge of how it works or where i can find wiring diagrams??
  16. #28
    Quote Originally Posted by oldguy2 View Post
    is it an HEI ?
