Boat Weight ?????
Page 1 of 2 12 LastLast
Results 1 to 14 of 17
Boat Weight ?????
    Southwest corner AR
    Default Boat Weight ?????
    I am having a custom boat trailer built and I need to know the weight of a 19' Spectra with a BBC an a berk. pump? Any ideas!
    WT
    FAT GUY IN A TPR STEALTH NO REGRET$'s Avatar
    MENIFEE . CA
    WT
    hull 450 lbs. motor about 750 lbs. pump 100lbs all the shit 300lbs + my fat ass 348lbs 19ft TPR....
    "Life's tough......It's even tougher if you're stupid."
    -John Wayne
    ..JUST HAVING FUN..
    . . . .SIPPY CUP RACING. . . .
    MySpace URL:
    http://www.myspace.com/dp734taj
    So Cal
    Hard to say, you have truck scales & a lake near your house? Weigh your truck/trailer/boat & then go launch your boat ... go back and re-weigh. it's the only true way to know.
    Everyone can guess for you, but this is the best way to know for sure.
    Remember to have the same amount of gas in your truck, or close to it.
    Newton Ks.
    My heavy-hulled Taylor SS is supposed to be 1860# from the factory. Yours has to be several hundred pounds lighter.
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Quote Originally Posted by NO REGRET$ View Post
    hull 450 lbs. motor about 750 lbs. pump 100lbs all the shit 300lbs + 19ft TPR....
    Nice!!!!!!!
    Monroe, WA
    A 19 should be real close to 2000 lbs complete.
    Malcolm
    75 Spectra 18
    76 Spectra 19
    Goin for the whole set...
    Southwest corner AR
    Quote Originally Posted by Malcolm View Post
    That is what I was thinking I said around 2300#. Thanks
    Member 19Daytona's Avatar
    King george, Va
    Default Weight
    Most tandem trailers have 3500# axles under them, You have to figure in the weight of the trailer which for a good custom trailer can be 900 to 1100 pounds plus the boat and items in it, I have a Competitive trailer that weighs 950 pounds.
    Southwest corner AR
    Quote Originally Posted by 19Daytona View Post
    I am letting the trailer manufacture to select the # of the toursion axles that will be supplied! I just needed the est. weight of that type of boat!
    Newton Ks.
    Don't know why you'd put tandems under one ton of boat, other than the "chain one up in case of a flat" reason.
    Beat the heck out of a boat putting 2,000 pounds atop a suspension designed to carry 7,000 pounds.
    No, "towing straighter" is invalid, unless the single is made crooked. My single axle trailer (straight and square) tows and tracks perfectly, at all speeds, on radial tires 9no "hunting" or "swerving", at all.
    Canyon Country, CA
    a good trailer builder can set up a tandem trailer for a smaller boat. i dont know about anyone else but the reason i prefer a tandem is strictly for looks. single axles look lame to me. ya know getting there is half the fun
  13. #12
    Monroe, WA
    Just because you put 3500 lb axles in, doesn't mean it's going to have 4 or 5 leaf springs on every corner! Mine only has 2 leaves on each wheel and rides real smooth.
    Also, you'll think about adding another axle to your trailer the first time you have a blow out on your single. Been there! No fun...
    Malcolm
    75 Spectra 18
    76 Spectra 19
  14. #13
    Santa Clarita
    Single axle trailers are for 16' aluminum fishing boats.
  15. #14
