ohm's for fuel sending unit
Results 1 to 12 of 12
    Nov 2009
    Thumbs up ohm's for fuel sending unit
    Hello, I have a 1972 Southwind with a new 555 BBC and Jucuzzi pump, and I am replacing all the gauges. What ohm gauge should I get for this boat. It has the two side tanks, that are 12 gallons each. They make about 7 different guages with different ohm's so I need to know which gauge to get. Thanks, 2Stout.
    it needs to match your sender,
    marine senders are normally 240 ohms empty and 33 ohms full
    #55
    Nov 2009
    Thumbs up 2Stout
    Yes, it has the stock guages in it now, but do not work. That is what I needed to know what the original ohm's are coming from the sending units in the tanks. Thanks for your time.
    Quote Originally Posted by 2Stout View Post
    You need to take an Ohm meter reading when senders are on empty, most read 240 when empty, and that value goes to 33 ohm or so when reading full. Most fuel senders are 240-33 ohm units in boats.
    Nov 2009
    Langley, B.C. Canada
    Ya the readings a very nominal figure out which way the gauge runs I seen some that a back ward grounded reads empty. So ground out gauge for a sec then check to see if gauge reads full or empty, if nothing happens for looking at wiring. If it moves you'll have to order a new sender.
    Morgan Hill
    Or.....use my method, wallet thin = boat full, wallet thick = boat empty
    The backward reading dealio is the 90 ohm GM deal.
    GT
    GT
    Nov 2009
    something to add how many people have had or do have fuel sender problems with the gage being very erratic and what they did you fix them, in my case it was a sloshing problem, i used a capacitor between the signal wire and the power 3800 mfu slowed the gage seems to be good but is there a sender i could buy that the sloshing doesn't effect? do the float less gages correct this or should i just stick with my fix
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Quote Originally Posted by lefty's pride View Post
    I use this one from Hardin Marine. Very accurate and easy to install. 33-240 Ohm. 3 wire or two wire connection.
    “XS” Xtreme Series Fuel Level Sender
    GENERAL DESCRIPTION
    The ELECTRONIC SENDING UNIT for FUEL tanks provides a continuous
    readout of the liquid level in your tank. The unit (which has no moving
    parts) consists of a sensor probe and an amplifier. The amplifier components,
    which are located in the mounting plate assembly, are encapsulated
    in an epoxy resin compound to seal out moisture and other contaminants
    which could affect the operation. The mounting plate assembly
    has the same 5 hole SAE bolt pattern mounting dimensions as the
    standard float sending units they replace. The meter (receiving unit) can
    be remotely located close by or in your dash.
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Simply Centroid Senders...
    Yes they will stop the slosh effect to a degree as there is no float to bounce around wildly.
    240-33 ohm is standard for most aftermarket marine gas gauges. They bolt in place of the float style (std 5 bolt pattern) and do require 3 wires (one more than float type).
    That is the one.
    Member danfornow1's Avatar
    Sep 2009
    Troy, IL
    So what does the third wire do, where does it go if you have the old two wire style?
    It's power, ground, and sender, the Centroid senders are the best imo for fuel qty. Simple cut to length, and calibrate, calibration allows accurate fuel qty readings.
