So, I purchased a complete kit with hydraulic pump rather than a manual control..I am looking for pix of your installation on your boat.I also upgraded to the steering wheel mounted trim switch.Looking specifically for pix of the pump installation, and pix of the transom where the hoses go through it.I dont want to do this job and wish I had missed something. If you think there is anything I need to know...LET ME KNOW!!! Thanks in advance,Jack....Edit...19 foot Gullwing,dunno if that matters.
Looks like a really nice clean installation, Thanks for your input.I am really interested in pix of the insallation of the pump and the thru-transom- installation of the hoses also.
Albert those pics are great I just copied them for my Place diverter install tutorial !
Sunkist don't forget the "loctite" applications on the attaching screws ! mount the pump "dove tail' bracket to the transom wood or stringer and be sure to allow for the extra height of the Plexy cover dome and plan your hose hose routing , the lines are supplied with two small black water tights that can be threaded either into the actual transom itself or the transom adaptor casting (upper right or left corners if room) (1/2" fine thread tap required) I'll look for some pics for you call if we can help Tom
