lol
lol
i ran into this same problem when i de-hooked my boat.when i had alot of hook i could be in the full up position all day not anymore.
1 solution id to jack the ride plate down this has helped some peeps.wish you luck and these fellas will help you out.travis
Bow tank? Equipment under the deck?
Seriously, more HP.
More HP equates to more output pressure, which will set the boat more firmly against the ride plate, which stops the porpose.
I can run full up diverter with less than full throttle only on absolutely perfect water. Any chop at all trying to cruise with it up makes her porpose. Full throttle will carry the bow, but less pressure will not.
You could also lower the ride plate some, to not allow the boat to nose up as high before getting a good lean against the ride plate. This may help as well, but may cost you top end speed.
My boat will porpoise if I raise the diverter in the 3k-3500 rpm range. Trim it out (get rid of the rooster) or throttle down.
unless you have a serious hook in the hull,i would look into ride plate adjustment.make small adjustments untill you get it right,i wouldn't just jack it allthe way up or down.i would drop it about 1* at a time.
Sounds like you may have rocker in your hull. If you do, put on a set of these and be done with it.
http://www.glenwoodmarine.com/Catalo...%20CATALOG.pdf Look on page 64. We sell them.
Then you can throw all the rooster you want to.
Duane HTP
www.hi-techperformance.com
Muahahahaha!Not sure what the bowtank comment was about, mine has one & I can still throw a pretty healthy tail.
Bowtank adds weight to the front of the boat
