lacquer paint??
Results 1 to 6 of 6
lacquer paint??
    Apr 2009
    SW Ohio
    Default lacquer paint??
    Looking for a super cheap paint job to freshen my (cheap!) boat this winter. Summit has the $20/gallon lacquer paint that is supposed to lay down as nice/nicer than the old school lacquer without the ill aspects. The old corvettes seem to hold up with lacquer over fiberglass without too much issue. How about on a boat? Thoughts? seems alot more forgiving than the base-clear systems, and probably as durable I imagine. re-gel is out of the question due to $$$ and the boat not being worth it.
    Thoughts?
    when the stuff starts lifting or flaking, you will wish there was an easy way to get it all off.......
    Apr 2009
    SW Ohio
    good point on the flaking. I forgot to mention some previous owner fogged clearcoat over the (faded) original gel. Its flaking off all over the place. Nice.
    So no matter what I do it will end up well sanded for whatever gets painted on.
    Don't Member Blow It Up's Avatar
    Sep 2009
    Yucca Valley
    Lacquer and water don't mix we'll.Go down to auto parts store and get a gallon of one stage.Spend a hundred and save your self tons of problems.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    You might even want to talk with a local bodyshop and see if you can work a deal with just spraying the boat, we'll get you set up on prep! thats the toughest part, but when that is all handled, the painter should be able to handle it pretty reasonably! just a thought!
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    I used Dupont Imron on the bottom of my boat and it worked really good, no flaking or peeling. Its not that expensive either, and it sprays nice.
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
