Reverse Gate Question
Results 1 to 2 of 2
    Apr 2010
    Default Reverse Gate Question
    I have a Berk 12JG with a droop snoot. It had the ram horn shaped reverse gate on it which broke. My question is can I use the standard reverse gate on this setup or does it have to be the ram horn style?
    Thanks!
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    Quote Originally Posted by trickyrat View Post
    Thanks!
    If you use a standard reverse gate there will b nowhere for the water to go. You need a ram horn or set up the standard gate like this---->
Name:	old schools pump.jpg
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
