Slick50, Dura Lube? any luck with these?
Page 1 of 4 1234 LastLast
Results 1 to 14 of 56
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default Slick50, Dura Lube? any luck with these?
    Dura lube is $15 bucks at walmart with a $10 rebate. Think its worth it? anybody have any luck with these engine treatments?
    Quote Originally Posted by sleekcraft137 View Post
    I use 9 qts val 20/50 racing with 1 qt lucas.
    Made In The Shade
    Custom Window Tinting
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    ZZ502 in a jet daycruiser. 5200 rpm/63 mph. 9qts 15/40 & 1 qt Lucas'.
    Change oil about every 50 hrs.
    Loose, the Dogs of War!
    Star, ID
    so I take it that the lucas product is worth it then huh?
    I received a email the other day about additives from Amsoil. I will need to find it. Most but not all are safe to use. Seems they give off a Sulfuric acid or something. I will look for it. Seems like Lucas was one of the ones that did. Now flame away till I cum back now.
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    I've used Slick 50, Prolong, Motor-up, Duralube, Sea Foam, and probably a few others.
    ALL snake oil IMO.
    Prolong and Duralube are essentially glorified paraffin wax.
    I poured some Prolong into a BBC a while back, and within a week, the cam lobes disintegrated because the lifters stopped turning.
    If those products did anything at all, manufacturers would require them.
    In fact, the only motors I HAVE had problems with, were ones that had that crap in them.
    I put Mobil 1 in everything I have with a motor in it.
    Zero problems.
    Oh, and the AmsOil lie about a 20,000 mile oil change makes me laugh.....gimme a break.
    Star, ID
    Quote Originally Posted by jet460 View Post
    ALL snake oil IMO.
    Zero problems.
    yeah right 20k......lol, but you need to change your filter 5 times!
    Mar 2010
    Modesto, Ca.
    For what it's worth, 2 friends of mine have Olds 455 jets.
    They use Rotella exclusively, and have for years.
    15 years with no problems at all in both boats.
    I change my oil every 2 trips to the lake.
    Best insurance I can think of....
    Star, ID
    coolness, i just bought this boat last week and want to keep this motor strong. It only has 8 hrs on the rebuild. I did a compression test last night and it came out GREAT! 175 on the high and 170 on the low. everything else was right in between
    Mar 2010
    Modesto, Ca.
    If you are like me, and running a fairly mild engine and pump gas, you might try a bottle of double strength 104 octane boost. The stuff you get at Kragen, etc.
    1 bottle to 30 gallons of 91 pump gas changed the entire sound of my engine(460), and made it run a LOT better.
    The only shelf additive that I have noticed a difference with.
    Star, ID
    up here in Boise you can get 93 octane at a few stations and 94 in a couple others. But i'll give the 104 a try
    Mar 2010
    Modesto, Ca.
    Nice. In Cal we get winterized coyote pee.
    Star, ID
    Nice. In Cal we get winterized coyote apee.
    and a butt load of traffic! i grew up in OC....NO THANKS! id never move back!
    octane booster changed the way your engine sounded?
