Oil Recommendations - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 15 to 28 of 29
Oil Recommendations
  1. #15
    I'll check that link and I've tried signing up on 460ford.com about a dozen times with no luck. Thanks
    After you run it one weekend switch to a 15-40 or 10-40 synthetic.
    On the 460Ford.com issue, it took 5 days before I received a conformation email. You need to check your spam email, because that is where it will go.
    Sleeper CP
    Default oil$
    We use and recommend Shell rotella for Cam breakin Then Torco , Solid stuff !!!
    http://www.torcoracingoils.com/
  4. #17
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Well, I picked up 3 gals of Rotella 15W-40. So that's what's in the motor.
  5. #18
    Newton Ks.
    Being your engine is still new, I don't think you want to run a synthetic just yet?
    I seem to get all kinds of stuff wrong, but I broke mine in on Syn, same Castrol I still run, with no problems.
    Maybe that's part of the reason the cam break in survived.
    H.L. Mencken
  6. #19
    Cas
    Cas is offline
    Angry American Cas's Avatar
    that's why I put the question mark, I've heard lots of pros and cons on that subject.
  7. #20
    San Francisco Bay Area
    Cool
    My oil is at 80 psi with the 20-50.
    If your operating your mild engine build in typical jet boat fashion and have 80 psi with 20w-50 petroleum based motor oil, then i would say that you can try some 10w-40 and see what that does for your oil pressure. Generally, 80 psi is acceptable oil pressure and most people might tell you to stick with it. No argument there; frankly 70 psi is perfectly fine too in a mild build and this is why I think you might want to try the 10w-40.
    Also, things may change in a few months...beware that during hot peak summer days you just might find that twenty-hour-old 10w-40 petroleum based motor oil just isn't cutting it anymore and your oil pressure is lower than you may like to see. Adjust accordingly...be it stepping back up to 20w-50 or maybe synthetic 10w-40 (after a thorough break-in), etc.
    In short, for a mild rebuilder 460 with carb, intake, small cam, etc, I wouldn't want to see anything over the 80 psi that you have.
    I posted this reply on the other forum as well....
    LO
    High Flow Dynamics
    This post © Copyright 2007-2012 Paul Kane. No copying, linking, printing or otherwise without express written permission.
  8. #21
    Lexington, KY
    Question
    Sorry about the thread jack. When I was trying to start my engine, the oil pressure gauge shoots straight up to maximum oil pressure on the gauge. What is the reason for this? And should I be worried about it? Don't know how it is going to act when the motor gets completely back together after being completely torn down, but that is what it was doing when we were trying to start it a couple of months ago. Can't remember what the max on my gauge is. Thanks. HJ
  9. #22
    Are you saying the guage "spikes when you turn the key on? , bad dash ground or wrong/shorted oil sender ,disconnect the sender wire ,insulate the wire and turn the key on ,post the results Tom
  10. #23
    Lexington, KY
    Only when when I crank the engine, not when I turn the key to on position. It spikes and stays spiked. The oil sending unit is brand new and I'm pretty sure it is the right one, it is the same as the one that came with the boat, but does anybody have any pictures of theirs for a BBC. What do you mean by "insulate the wire"? Sorry won't be able to post the results for a couple of weeks, when I get the motor back in order. If it is still doing it when I get it all back together I will give you a call. It will probably still be doing it because it did it consistently from the very first time I tried to start the motor. Thanks Tom. HJ
  11. #24
    Cas
    Cas is offline
    the sending unit needs to be matched to the gauge. For instance, a sending unit for a VDO gauge won't work with a Stewart Warner gauge.
  12. #25
    Lexington, KY
    Angry
    Really, well that sucks for me! Fuck!!!! I guess I'll have to look at what kind of gauges I have tomorrow, and look up sending units for them because I probably need the water temp one too because that one is the original one that came with the boat, and I ditched all of those gauges awhile ago. Thank you.
  13. #26
    Cas
    Cas is offline
    don't fret too much yet. Some sending units work with multiple gauges, maybe you'll get lucky and only have to find the cause of the erradic needle peg
  14. #27
    Lexington, KY
    Thanks. I really hope so. I'm tired of taking all of these steps backwards. I wanna get the damn thing in the water by June. May ain't gonna happen, too much other stuff going on, plus every time I make any kind of progress I take about 5 steps back.
  15. #28
    Cas
    Cas is offline
    Don't think you're the only one that's been there. Most people that have restored a boat to any degree has been through the same thing. Just take your time and ask questions (like you have), you will really be better off in the long run.
