low profile intake?
Results 1 to 7 of 7
low profile intake?
    Senior Member badbug3's Avatar
    Default low profile intake?
    whats the purpose of a low profile intake and under what conditions would u need one?
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Quote Originally Posted by badbug3 View Post
    Engine cover would dictate needing one
    [/SIGPIC]
    Senior Member bc18's Avatar
    Good question cause I wanna know to
    Senior Member harley222's Avatar
    Sep 2009
    being able to get under bridges that are low....idk lol
    some boats will get the point where they have to feed the pump alot of shoe or loader to maintain intake pressure, well that's a bad thing if you expect a nice shutdown too. say your clipping along at 110, it takes alot of hardware to keep the pump fed , otherwise itll jus "run over" what water is available to load since the angle is steeper to the pump and your moving so fast. low pro intake drops the pump down further into the water plus has alot less throat angle for the water to have to "climb".not necessary to get all stupid with hardware bite to get the same intake pressure you normally would, if that makes sense. im sure there's other reasons, but that's my reasoning. less friction between you and the water=faster
    s480@18lbs nto 325cubes of whoopass : ) turbo boyz
    does this mean that it only helps when you are going a 100 or more? seems like it would help with the take off no?
    6TH STREET TERROR 4 HIRE -RUSSO-'s Avatar
    HESPERIA.
    -FIX IT FASTER-
    -6TH STREET MAFIA -NOMAD-
