vaccum secodaries
Page 1 of 2 12 LastLast
Results 1 to 14 of 20
vaccum secodaries
    Cheers for beers! DELTA~HOLIC's Avatar
    Newman CA
    Default vaccum secodaries
    I have a Holley Carb and the vaccum secondaries aren't opening. I had one of my buddies check them as i was WOT and they didnt open. Once he stuck his hand down there and opened them manually I gained an additional 500 RPM's. I took apart the diaphram and everything looked legit. He was saying I possibly need a lighter spring, but I would like your guys input. Thanks!
    Santa Clarita
    Mechanical Secondaries and call it a day....JMO
    Kingman/Golden Vly, Az
    yup...Holley sells a complete spring kit...it includes colored springs in different strengths ...you might be able to find it at Checkers, Auto Zone, Napa etc or else Summit, Jegs carry it...just sayin'
    FastRat
    Start with the mid-strength spring. Other than that a DP. I hate vac sec carbs on jet boats.
    S CP
    Aug 2009
    O.C. & Lost Lake
    There is a hole in the primary side of the main body down in the venturi. The air passing by this opens the secondaries. Make sure the hole is not plugged up. I have blown down the venturi with an compressed air and made them open.
    Menifee
    S CP
    Are you crazy!!!??? Vacum sec carbs work great on Jet boats. I used one for my Bahner. Everytime I unhooked it from the truck I would throw an old 3310 under the trailer tire to keep the thing from rolling out of my garage.
    Keith...
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Thumbs up
    Lend me your boat. I'll fix it!
    Nice ride. Been out lately?
    Loose, the Dogs of War!
    Stick a small bolt through where the arm connects to the primaries so when you floor it the arm will open them manually.
    Vinyl Graphics, Magnetic signs, Reg #s, Boat names, Banners, Boat decals, Etc. Please contact me Via facebook or e-mail cycodesigns@hotmail.com.
    Senior Member G-Body's Avatar
    Downers Grove
    I have a 650 vacuum on my 305. I put the lightest spring in and it would not open all the way. I was swapping springs out and noticed the little ball bearing that slows the secondary opening so you dont get a bog.....you know the one that holley says never to take out. Well in my application taking it out worked out very well. Secondaries open every time now and I don`t even have a bog.
    10' Custom with 25 Merc_____17' Sleekcraft jet____85 El Camino SS 5.3L/4l60E 3.73 posi____1980 Chevette 4.3L v6/4l60e____www.fquick.com/G-Body
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Quote Originally Posted by Burnt Sticks View Post
    Mine did the same thing.
    Plus, I switched to the lightest spring in the kit when I rebuilt my 4160's.
    Newman CA
    Quote Originally Posted by Schi-502 View Post
    Anytime Mark. I went out last Sat, how bout you?
  13. #12
    Newman CA
    Thanks guys! I will fool around with it a little more to see if I can get them to open, if not I will just go mechanical. Seems thats the way to go!
  14. #13
    The Right Coast/SE-PA
    Thumbs up
    Heck, you would have to pry my Holley VS carb from my dead cold hands before I would give it up.
    Offers good cruising economy and it still hits hard when the go-pedal is punched down.
  15. #14
    Senior Member splatter's Avatar
    Sep 2009
    The NC
    I had a stock 460 in a cruiser with a 850 dp on it. Performance wasn't an issue with an old heavy tub with a stock motor so I put a 750 vc on it for kicks. It didn't lose any top rpm and it cut fuel consumption by a bunch.
