Removing Painted Graphics
Page 1 of 2 12 LastLast
Results 1 to 14 of 15
    Coeur d'Alene, Idaho
    Default Removing Painted Graphics
    I've removed painted graphics on gel before with oven cleaner..what is the process for removing painted numbers and names on paint..not gel..thanks
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    got a pic ? it would be paint on paint correct
    [/SIGPIC]
    Quote Originally Posted by Lucky View Post
    Yes..paint on paint..
    Ukiah,Ca
    simple graphics ?
    [/SIGPIC]
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    thats a million dollar question! Too many variables -if they will come off at all. If they were hand lettered with sign painters enamel-you can try easy-off in a spot that isnt seen to see if the paint reacts to it.
    WFL CREW!
    http://www.performanceboats.com/cont...-magazine.html
    Everybody wants some...I want some too!
    simple graphics ?
    Yes..ID numbers..sprayed on with an air brush
    Aug 2010
    wetsand/rubbing compound with a DA. it'll take some time but using a chemical on your paint might remove more than you're hoping...
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Seams I remember something about a similar situation some time back.
    If the boat is painted in lacquer and the lettering is enamel do a test spot with some enamel thinner and see if it affects the lacquer. If it doesn't hurt the lacquer you might be OK.
    Where is Todd on this?
    Im non induced and My turd leaves pretty hard as she sits.
    I've used Goof off,graffiti remover, and enamel reducer. Just try some on a rag, a little at a time. Last one i did left a red tint in paint. Then i parked it in the sun for a week and it was gone. Just be slow and take you're time. Good luck
    Here is a photo..need to remove the numbers..not the flames.
Name:	Picture 4410 - Copy.jpg
    Ukiah,Ca
    Quote Originally Posted by Tittyman View Post
    color sand and polish - take you time and watch what your doing ! I would start with 400 and work my way up to 1500. better not get in a hurry
    [/SIGPIC]
  13. #12
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    X2, I recently did this for a customer, not knowing how much clear is on the boat doesnt help either...but to take precaution...Mask off the area that you dont want to have to mess with, I used 1500 wet and tried to sand with the brush strokes, then when it was mostly all gone, I block sanded the entire area until it was gone, as it got real close to all being gone, I changed the grit to 2000, and was ready for buff in no time, just my opinion.
  14. #13
    Senior Member sleekcraft137's Avatar
    Star, ID
    400??? wow that sounds really aggressive! would a 1000 with a little more elbow grease be safer?? Just curious......
    And the new project begins!
  15. #14
    TRG
    TRG is offline
    A freash sheet of 1500 is pretty aggressive when using your fingertips, thats why I started with that, the lettering enamel sands off real quick, so if you can get away with leaving more of the surface paint the better!
    After re-reading Luckys last post, I noticed the 400 that he used, I rerely use 400 on any painted surface, mainly for a run, but those are few and far between! you would think I was a marathon participant! lol
