Daytona 21 question
Page 1 of 2 12 LastLast
Results 1 to 14 of 27
Daytona 21 question
    Nov 2009
    Default Daytona 21 question
    I'm thinking about purchasing a 1979 Eliminator Daytona 21 jet. just wanted to know the plus or minus on a daytona of that age. What i should look for. It was original a jet from eliminator. I've been looking for a 21 Daytona for a while now, just don't know much about the differences in the hulls throughout the years. Any help would be greatly appreciated.
    Wet
    Wet is offline
    East Hampton, CT
    Don't pass it up, you'll regret it.
    Quote Originally Posted by stewvette View Post
    Stick a pic up....I love my 1981 21' daytona. If you need help with the pic pm me. Is it orig gel everywhere? Check the stringers ect.
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    Quote Originally Posted by Wet View Post
    X2 I love mine. 1982
    SAMSPARTS.COM
    Senior Member Tony Skagen's Avatar
    A 1979 Daytona had a flat keel! If it's a nice boat and the price is right dont pass it up just because of the flat keel, it can be fixed!
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    love my 83
    Senior Member 91foxbody's Avatar
    Stanwood, WA
    Wish I had one!
    concord, ca
    Default Daytona
    I can tell you, every time someone rides in my boat, they want one.
    Jerry
    The Right Coast/SE-PA
    You'll love-love-love the ride...but, in a JET application they DO require a LOT of HP (which I don't have) to make them work, and they don't even start working until it's well over 50 + mph.
    Clovis, Cali
    Quote Originally Posted by Tony Skagen View Post
    The early 21's had flat keels ? I thought all the 21's had rounded keels, but I'm still learning. What year did they change to the rounded keel ?
    Lookin' for answers. Pizzy's Avatar
    Tucson, AZ
    Like WET said don't pass it up, I love mine! The most stable ride ever IMHO!
  13. #12
    corona calif
    Default 21 Eliminator
    As I remember when we tooled the 21 it had a small 5/8's radius on the center keel and is still the same bottom that you will find on the newer 21's. The 21 Phantom has a larger keel, never measured it but it appears to be possibly a 3/4 inch radius.
  14. #13
    Nov 2009
    Thanks for the help so far...Taking a long drive Sat to check it out. What would be the factory location for the pump? where would the clean out be located, middle of transom?
  15. #14
    You had better not dilly dally around > someone else will snatch that Hull up in a heartbeat!
    Factory location for the pump > it depends on where the owner wanted it (or) where Eliminator, or someone like Greg Shoemaker decided to put it.
    Originally mine was well inside the transom > I did the setback myself.
    Don't worry about where the pump is > just go get it
