mounting electric fuel pump...
Results 1 to 13 of 13
    Aug 2010
    Default mounting electric fuel pump...
    people with electric fuel pumps are you mounting yours directly to the transom or are you using any type of rubber to help deal with the vibrations? it seems like i turn my ignition on and its back there whirring away, pretty noticeable. just curious if anyone else had a problem/deal like this and if mounting it with some type of rubber isolator helped with the noise.
    Newbury Park, Ca/Bullhead City Az
    Default Sure....
    Quote Originally Posted by ka0tyk View Post
    Sure, you can quiet it down a bit with rubber mounts...... Also remember, electric pumps push, not pull like a mechanical.... Mount as close as possible to the tank(s)..........
    Ray
    LOUD BOATS SAVE LIVES
    3 OPEN flatbottom APBA seasons left.....Let's RACE
    HONK if you voted for obama........
    It's that button in the middle of the steering wheel........
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    On the transom...
    Loose, the Dogs of War!
    Senior Member TrollerDave's Avatar
    Chino,CA
    Mine is mounted on an aluminum plate that is mounted on the stringer.
    I'll try to get a picture up later.
Name:	fuel pump 001.jpg
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    mines mounted off my rail's
    Mar 2010
    Clarksville, TN
    I'm mounted on the stringer and once I fire up the BBC I can't even hear the fuel pump
    Aug 2010
    true, once its running u cant hear it. maybe its a good thing i can hear it before i start it... hrmm.
    I agree. If you can hear the POS after your start the boat, get some real exhaust!
    LINK:GN-RACING.COM
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    Here's another option for you guys too....
    http://www.cpperformance.com/p-13752...off-plate.aspx
    Maybe you could incorporate the MSD vibration mounts that they use on the ignition boxes to help also. Sure anything is better than nothing.
    http://www.cpperformance.com/p-257-r...d-6-boxes.aspx
    Brad
    CP Performance
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    1CALIFORNIA PERFORMANCE9 blender over's Avatar
    Murrieta/Big River
    Both of mine are mounted to my front motor plate, 1 on each side of crank wheel as low as they can go. Mallory marine 110fp
    Can barley hear them when the motor is off.
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    placecraft tunnel
ID:	86367   Click image for larger version.
  13. #12
    Apache Lake Monger AZKC's Avatar
    Tucson
    That block off plate mount is kinda spiffy I'm not a big fan of electrics, fire and electric fuel pumps always scare me.
  14. #13
    Promoting pollution Smog Pump's Avatar
    Sep 2010
    Pumpkin Center, CA
    I think mine is under the engine cover on my I/O somewhere.
