boat name PURPLE HAZE
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
    member
    Nov 2008
    Default boat name PURPLE HAZE
    Does any one know if this name has been used or is in current use? Also how do you pick a boat number? really wan't to stay away from names and numbers that have a past out of respect. Thank Scott King
    Owner/Crew Chief 1/4 Miler's Avatar
    Rural Missouri
    Jack Haze from San Angelo, Texas had a BFJ named 'Purple Haze".
    Senior Member bp298's Avatar
    LHC
    not unusual to see old names resurface on another boat.
    as far as a number, make a list of a handful you like, then call the club you're going to race with to see if they are available.
    member
    Nov 2008
    How would I get ahould of him to ask permission to use his boat name? Tradidtion and respect are pretty importantto me Thanks Scott
    It's really hard to come up with a good boat name that hasn't been used already. I'd say, as long as an active competitor isn't using it in you're association, you should be good to go. There are a few names like Madness and The Texan that I wouldn't use even though the competitors that made the names famous are not racing at the present.
    In asphalt drag racing, the use of car names has mostly been abandoned except in the nostalgia deal. Seems boats are heading the same way these days.
    member
    Nov 2008
    Thanks guys I have not heard of a blown fuel jet named purple haze, maybe it has been retired. Thanks for the replies guys. Purple haze it is then. I will find out thru SDBA what numbers have not been used and go with that. Scott
    Theres a pretty well known silverwing that has been in the magazines name "purple haze"!
    member
    Nov 2008
    Quote Originally Posted by riotact View Post
    Does it run with any of the sanctioning bodies?
    Kingman/Golden Vly, Az
    i "had" a name on my boat long long ago which happened to be the same as a board member!...he no longer has that name (chnged board name)...i may put it back on ...i find NO dis-respect for a prior name... if you like it...use it ...just sayin' my .02 cents
    FastRat
    member
    Nov 2008
    FastRat
    FastRat I believe out of shear respect some boat names and numbers should be retired with the great men and women that has done so much for our sport...especially the one's that where buried with them my 02 Scott
    Senior Member DonnyLe's Avatar
    Sep 2009
    Livermore, Ca
    Quote Originally Posted by Scott King View Post
    I would stay away from Purple Haze. Back in the early 80's a guy named "Purple Jack" Bennett had a southwind tunnel that was known to be on fire more and got a bad rap for that. It was a Top Fuel Jet that ran wrecking yard 392 Chryslers. It was always entertaining but never really a front runner.
  13. #12
    member
    Nov 2008
    Quote Originally Posted by DonnyLe View Post
    Thanks Donny, But purple haze has kind of stuck, I am not to worried about being a front runner, I just wan't to be in the program. Thanks Scott
  14. #13
    Hudson, Wisconsin
    Ironically, I have bought TWO boats that were named PURPLE HAZE. One was that Silverwing and also my last Sanger flat. Here's a couple of pics. Jocko
ID:	86505   Click image for larger version.
Name:	Silverwing TwinTurbo2.jpg
ID:	86506   Click image for larger version.
  15. #14
    Texas
    Thumbs up
    You might start on the boat number thing by going here...
    http://www.sdbaracing.com/html/points.html
    and scroll through the pages to see if the boat number you want has been used.
    Kenda Reedy, the SDBA Registrar has a list of numbers that have been retired in the SDBA for various reasons.
    You can contact her at membership@sdbaracing.com
