Banderlog launch controller
Results 1 to 8 of 8
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    Default Banderlog launch controller
    How do they work? What are they worth?
    Lexington, KY
    Question
    And what are they?
    HJ
    Surrey, BC, Canada
    That too actually!!!
    UMPBA.ORG sleekcrafter's Avatar
    Once all avenues are exhausted to make a boat launch, a launch control is some times needed. What it does in ramps the engine rpm's over a given time.
    Surrey, BC, Canada
    Kinda like a programmed rev limiter?
    Yes, you have a couple seconds of programmable rev limiting. It was designed specifically for drag racers. Pretty sure the concept has been copied by one of the major ignition system manufacturers albeit with a longer available time frame to be programmed.
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Default Old Squirt
    Did you try the impeller yet ? Did it work out for you ?
    Senior Member bp298's Avatar
    LHC
    shortly after the banderlog launch controller was designed and built, msd found out about the idea. they already had a timing control that was very similar, so created software to use with that box, and created the msd launch controller. the original banderlog would work most of the time, but as craig said, was only good for a few seconds. the msd could be programmed over a 12 second span, and the software was more user friendly. msd launch control was incorporated into certain models of the digital 7 box more than 2 years ago.
