{{Please help me identify these wires}}
Results 1 to 9 of 9
    "Floatin' Motor" BoNeS's Avatar
    Jun 2010
    Surprise, AZ
    Default {{Please help me identify these wires}}
    I'm trying to redo the wires on my terminal block, In my haste to beat the weather, i didn't match them up when i took them off. The wires goto my gauges, the wires are as follows...Purple, Brown, Grey, White, and Blue. The wires i took off are mismatched from the harness so i'm not able to use them as a reference. Thx in advance....
    Purple, Brown, Grey, White, and Blue... Typically.... purple is 12v switched ignition. gray is tach (depending on application) Blue is o'press, brown is temp, white should be larger wire ? and is likley soleniod
    call if you need help Tom
    Redding, CA
    Tommy
    Quote Originally Posted by ram78d10 View Post
    I've talked with numerous teachers
    all the teachers I have talked to agree
    That's their problem, they can't print money.
    Quote Originally Posted by cvxjet View Post
    I rarely meet people that are smarter than me-
    Jun 2010
    Surprise, AZ
    Correct, the white is larger (12ga). The others are 14ga. Can anything be damaged if i don't connect them correctly to the right wire??
    EDIT: Didn't see the schematic..thx.
    Quote Originally Posted by BoNeS View Post
    The guages can "spike" and be damaged internally and yes the white (sometimes with a yellow trace) is your solenoid "excite" wire coming from your ignition switch Tom
    Jun 2010
    Surprise, AZ
    Thx Tom....and "thatguy" for the schematic.
    Jun 2010
    Surprise, AZ
    Exclamation Got another question about this wiring.....
    The 2 wires coming off the top of the alternator (white or brown, can't tell), where do they connect to on the terminal block??
    EDIT: I know now that 1 of them gets 12v, not sure about where to put the other 1. As far as i can tell it would splice into the ignition, I just need to know for sure.
    Depend on what?whoose Alt, typically one is an "excite and one a ground , we use "self exciting One wire alts" pretty exclusivley maybe a pic would help ? Tom
    Jun 2010
    Surprise, AZ
    I think it's a Delco...here's some pics of the top, back and front. Plus a diagram i've been looking at.
ID:	110542Click image for larger version.
ID:	110543Click image for larger version.
    The back side pic is the best i could get...
