motor is a 396 with a 454 crank (434). i had small oval port semi-closed chamber heads, 10.5:1, with an edelbrock performer rpm and a 650 holey dp. I came across some iron merlin rectangle port open chamber heads w/ 1.88/2.30 valves, 9.5:1, i put a victor jr and a 750 holey dp on it. cam is a solid flat tapet, 258 duration at .050, .615 lift, 108 lsa. im running logs and 4" risers. pump is a fresch jg with a detailed bowl and b+ stainless impeller, loader and diverter.
i was turning 5200 rpm now im down to 5000 rpm. im thinking i need to go with a smaller impeller to make up for the bigger ports and loss in compression. i know its running a little rich but not enough to loose 200 rpm in my opinion. any input is greatly appreciated.
LinkBack URL
About LinkBacks
sorry to the OP for the sidetrack on your thread
