Battery pics
Results 1 to 11 of 11
Battery pics
    Costa Mesa, CA
    Default Battery pics
    Im taking the benches out and putting two bucketseats in the boat. I wanna mount the battery in the center where the back seat is.... Anyone have some cool pics of what they made.
    Colfax, Ca
    Battery is under the box.
    Senior Member Mcintyrelocal's Avatar
    Norco, CA
    This is where i mounted mine and my icechest goes right over it.
    TJS
    TJS is offline
    CT
    Mc. your boat is sick.
    Here is my mount. It is not in the middle but it will give you an idea of how to make a hold down and such. This is made from simple home depot alum. 1/8" thick flat and angle just along with some turned bushing all tigged together.
    T.J.
    Norco, CA
    Benner metals in fullerton off of St. College and Orangethorpe, not that close but wihtin 20 min.
    Costa Mesa, CA
    Quote Originally Posted by Mcintyrelocal View Post
    Thanks! Have you got the boat wet yet?
    Norco, CA
    This weekend should be the first time, i have to run the valves, make 2 water lines and am waiting on 2 peaces of linkage from enderle and it will be completely done.
    Glendale Arizona
    Quote Originally Posted by TJS View Post
    T.J.
    Another home made special. Not as pretty as TJ's. I can't weld alumium so had to bolt it together. It aint pretty, but it's sturdy.
    Senior Member TrollerDave's Avatar
    Chino,CA
    That is alot of work for a boat you're selling.
    Or are you keepin it?
    Patton Steel in Ontario on Mission Ave. just west of Grove.
    About 15 min. from the 60/57 interchange.
    45 minutes if you try to leave at 4pm traffic sucks!
    TJS
    TJS is offline
    CT
    Nice and simple Squirtcha. Looks good.
    T.J.
    Glendale Arizona
    Wish you were closer. I could use your welding skills to put some of this stuff together. Nuts and bolts tend to loosen up over time.
