1979 Southwind tunnel build - Page 20
Page 20 of 22 FirstFirst ... 10171819202122 LastLast
Results 267 to 280 of 297
  1. #267
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Quote Originally Posted by swtd View Post
    let's plan a Elsinore southwind owners get together???
    come to the cp regatta futs and I will be there for sure as well as jake and kevin i do believe. would be rad if we could get 5 dragsters together.
    SWTD Member M/E 177 jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    yup i will be there. should be a great time.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
  4. #269
    Carlsbad, Long Beach, Big River California, United States
    Quote Originally Posted by HBInHeat View Post
    Would be pretty cool
    1978 Southwind Tunnel Dragster
    LS powered
  5. #270
    yeager, Do you have a guy to do polishing for your'e rails and plates? Mark
  6. #271
    After polishing rails in my other boat and having chrome ones in my new one, chrome is definitely the way to go.
    LS powered
  7. #272
    Sep 2010
    Yeah no polishing. Powder coat on most of it.
    Flow coat is going in today.
  8. #273
    Quote Originally Posted by jyeager View Post
    That will look nice on that flooring! Ever think about anodizing? the guy that does my work does both! Just a thought! Mark
  9. #274
    Sep 2010
    Yeah i've though about it. I got my guy doing it over here. thanks though.
  10. #275
    Razor Wire Militia ÷×§mᮆÚš×÷'s Avatar
    Lake Havasu, AZ
    Quote Originally Posted by sandeggo View Post
    that's why I chromed everything in that boat....
  11. #276
    Las Vegas, Nv
    Default Gelcoat
    Hey JYeager, what brand of gelcoat did you use? Did you use an additive to the gel, like duratec or prestec clear additive? Is the clear top coat a clear gel?
    Also I see that you primerd the whole boat, was the primer a poly primer?
    The boat looks awesome, You are doing a great job....Thanks....Hal
  12. #277
    Quote Originally Posted by ÷×§mᮆÚš×÷ View Post
    Makes cleanup a breeze! Thanks Shawn
    LS powered
  13. #278
    Sep 2010
    Hal, All the gel and primer was poly from Prestec. I only used the gel and thinned it 10% with acetone. i color sanded and buffed then used a 2 part clear of Prestec super clear and TX-2. Thanks for the kind words hal, your Kona project is what inspired me to take this one on.
  14. #279
    Sep 2010
    Flow coat is done.
ID:	164393   Click image for larger version.
  15. #280
    Sep 2010
    Got more done today. Have to take advantage of the time I have left before summer school starts on Monday. Got the gauges in and the scoop gelled
ID:	164608   Click image for larger version.
ID:	164605   Click image for larger version.
ID:	164606   Click image for larger version.
