turbo wogs project - Page 2
Page 2 of 35 FirstFirst 1234512 ... LastLast
Results 15 to 28 of 487
turbo wogs project
  1. #15
    sacramento
    had some problems with the piston rings. i had no champher left after block was bored over .100. these ring compressors didn't work. i wound up getting a solid tapered 1size fits only 1 size type from summit that worked great.
ID:	141824   Click image for larger version.
ID:	141825   Click image for larger version.
ID:	141826   Click image for larger version.
ID:	141827   Click image for larger version.
    sacramento
    had to make more room for the rods . at the bottom of the cylinders
ID:	141830   Click image for larger version.
  4. #17
    sacramento
    thrust bearing clearence was a little tight
ID:	141832   Click image for larger version.
ID:	141833   Click image for larger version.
  5. #18
    sacramento
    i had the dampener sized & it was too tight still. the washer cupped in & i never did get it on all the way last time . so i mixed some bearing lube with the anti-seize to make it extra slick which worked out well. i iced the crank down & put the dampener in the oven on a low setting & checked it with the laser temp gun to make sure the rubber wouldn't get too hot. i think i got it to 160* if i remember right. barely got it on all the way & the new washer cupped too. it was a mr. gasket i believe . well i ordered the one from arp to put on now.
ID:	141835   Click image for larger version.
  6. #19
    sacramento
    checked the piston to valve clearance after grinding on the pistons & had the 1/2 studs put in to get rid of all the helicoils.( i was getting water in the oil a little more than should have been )also ground all the bolts on the inside of the intake ports to flow better
ID:	141837   Click image for larger version.
ID:	141838   Click image for larger version.
ID:	141839   Click image for larger version.
ID:	141840   Click image for larger version.
ID:	141842   Click image for larger version.
  7. #20
    sacramento
    annealed the copper gaskets cleaned with scuffing pad & installed with hylamar instead of copper spray this time.
ID:	141844   Click image for larger version.
ID:	141845   Click image for larger version.
  8. #21
    sacramento
    messed around for quite some time getting the t&d set-up installed .cut one of my push rods to get the length correct. didn't have an adjustable one & wanted to order right away.
ID:	141847   Click image for larger version.
ID:	141848   Click image for larger version.
ID:	141849   Click image for larger version.
ID:	141850   Click image for larger version.
ID:	141852   Click image for larger version.
ID:	141853   Click image for larger version.
ID:	141854   Click image for larger version.
ID:	141855   Click image for larger version.
  9. #22
    sacramento
    school of hard knox lesson 10 ,don't do this or it will break.i was opening the valve all the way . i guess if you go over the gauge reading it screws up. had to sent it back to get fixed.
ID:	141857   Click image for larger version.
ID:	141858   Click image for larger version.
  10. #23
    sacramento
    port matched the copper exhaust gaskets & spacers the best i could & put bigger studs in
ID:	141870   Click image for larger version.
ID:	141871   Click image for larger version.
ID:	141872   Click image for larger version.
  11. #24
    sacramento
    the waistegate adapters they sent me were hideous,one welded on flange was mild steel & the rest was stainless. so i cut the mild steel off & made my own as i couldn't find any around,also did some minor changes to the adapters
ID:	141875   Click image for larger version.
ID:	141876   Click image for larger version.
ID:	141877   Click image for larger version.
ID:	141878   Click image for larger version.
ID:	141880   Click image for larger version.
ID:	141881   Click image for larger version.
ID:	141882   Click image for larger version.
ID:	141883   Click image for larger version.
  12. #25
    sacramento
    more pics. i have never welded stainless before. I noticed the new helmet doesn't work as good as the old one i have . i was pretty much blind as soon as i started welding 2-3 second welds hoping i was on track
ID:	141885   Click image for larger version.
ID:	141886   Click image for larger version.
ID:	141887   Click image for larger version.
ID:	141888   Click image for larger version.
ID:	141890   Click image for larger version.
ID:	141891   Click image for larger version.
ID:	141892   Click image for larger version.
ID:	141893   Click image for larger version.
  13. #26
    sacramento
    had to build the dump tubes for the waste gates ground & smoothed the welds (didn't look too good at first)
ID:	141895   Click image for larger version.
ID:	141896   Click image for larger version.
ID:	141897   Click image for larger version.
ID:	141898   Click image for larger version.
  14. #27
    sacramento
    had to figure out the plumbing next.gotta water cool the turbos & figure out where to dump it.
ID:	141900   Click image for larger version.
ID:	141901   Click image for larger version.
ID:	141902   Click image for larger version.
ID:	141903   Click image for larger version.
  15. #28
    sacramento
    more plumbing pics. see how i install the fittings ,even the aluminum wrenches mark up the fittings so when they are brand new i install them like this. its about the only thing this china made extension is good for i think i might put the turbo oil filter in this location .it will be out of sight here (below the back of the boat ) .
ID:	141910   Click image for larger version.
ID:	141911   Click image for larger version.
ID:	141912   Click image for larger version.
ID:	141913   Click image for larger version.
ID:	141915   Click image for larger version.
ID:	141916   Click image for larger version.
ID:	141917   Click image for larger version.
ID:	141918   Click image for larger version.
