turbo wogs project
Page 1 of 35 123411 ... LastLast
Results 1 to 14 of 481
turbo wogs project
    sacramento
    Default turbo wogs project
    well i'm board & its cold outside so i am going to post a bunch of pics of my fiberglass repair & motor etc.
ID:	141677   Click image for larger version.
ID:	141678   Click image for larger version.
ID:	141679   Click image for larger version.
ID:	141680   Click image for larger version.
    sacramento
    i got pi**ed off it cracked yet again so i cut the whole dam area out & started fresh.
ID:	141682   Click image for larger version.
ID:	141683   Click image for larger version.
ID:	141684   Click image for larger version.
ID:	141685   Click image for larger version.
    sacramento
    i think these are 1/2 done pics
ID:	141687   Click image for larger version.
ID:	141688   Click image for larger version.
ID:	141689   Click image for larger version.
ID:	141690   Click image for larger version.
    sacramento
    more pics
ID:	141692   Click image for larger version.
ID:	141693   Click image for larger version.
    Nice job...Do you plan on a speed coat... ect ? While your at that point, good time to do some other stuff.
    Made In The Shade
    Custom Window Tinting
    Senior Member Futs's Avatar
    Orange CA, Big River
    Nice job, now you get to do the same thing to the inside to make a complete repair. If you don't, its going to crack yet again.
    sacramento
    no speed coat this time. its already painted & buffed out sitting on the trailer . & yes i still have to do some on the inside. much easier. looking for the finish pics
    sacramento
    some pics from the bottom
ID:	141757   Click image for larger version.
ID:	141758   Click image for larger version.
ID:	141759   Click image for larger version.
ID:	141760   Click image for larger version.
    sacramento
    i found 1 finish pic. i wet sanded the back 1/2 ,buffed the whole bottom & waxed it a few times.i did not notice a difference in speed without the speed coat,as it was speed coated after the first bottom repair
ID:	141762   Click image for larger version.
ID:	141763   Click image for larger version.
    sacramento
    i also had my trailer fenders cracking the plates that they were bolted to . so i welded gussets. i resprayed the outside frame of the trailer & also added new bunks,carpet & a extra brace on the long bunk for extra support as people seemed to think this was the cause of the cracking . i don't think so but it wasn't hard to do . not sure if it will hurt or not though.flexibility on the trailer? i recommend if you are going to paint a trailer to check all the welds on the frame inside & out . my trailer was cover pass welded & bondoed over so the body filler would start cracking . the backside of the welds were not complete so the the welds were cracking.where the frame comes together in the front the plate has a weld that was not done right either & after the first paint job it cracked right away also, right under the bow eye.also i recomend adjusting the trailer bunks before you paint.
ID:	141765   Click image for larger version.
ID:	141766   Click image for larger version.
    sacramento
    these are the gussets . i also added a little stainless hardware & pulled the axle frame & assembly off the trailer frame to do this. i didn't want the welder to put burn marks into the frame paint
  13. #12
    sacramento
    found some pics of the trailer
ID:	141807   Click image for larger version.
  14. #13
    Chico, Ca
    I fixed a small crack on the bottom of my sanger cruiser, but nothing like this! What kind of boat is this? That's a ton of work.
    Andrew
  15. #14
    sacramento
    polished the pistons after i ground a little more relief for the valve.the valves were massaging the pistons
ID:	141819   Click image for larger version.
ID:	141820   Click image for larger version.
ID:	141821   Click image for larger version.
ID:	141822   Click image for larger version.
