Yet another Liberator 21 - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 27 of 27
  1. #15
    Nov 2011
    Default Hi - Tech Marine
    Sending my intake up to them for machining, shoe and rideplate.
    Their phone service and support is as I remember, just excellent.
    I haven't done business with them since they were in Goddard, over ten years ago.
    I am so looking forward to working with them again.
    Maybe I can sneek a few tips for the 21 footer.
    Senior Member cave's Avatar
    Mesa, AZ
    Your going to love the ride! Good luck!
    Takin it home
  4. #17
    Dallas, TX
    Might contact Dave at liberator. He might give you some insight on your boat.
    http://liberatorperformanceboats.com/
  5. #18
    Nov 2011
    Default Thanks everyone!
    Build pics coming...soon
  6. #19
    Nov 2011
    Default Steering
    Can anyone help me with the correct length, steering, throttle and up/down Morse 33 C cable lengths.
    Converting this to a jet from an outboard and I am not sure of the needed lengths.
    21 foot Liberator...
    Thanks,
    Kevin
  7. #20
    Nov 2011
    Default Need a little turbo help
    I am gathering parts for this project still. I have most of the Gale Banks kit from the eighties, less the carb box. The intercooler I have is like the one in the picture.
    It looks to have a standard 4150 base that will bolt up to a standard intake. I have researched many projects on the site and am a little confused. I assume this is a draw thru system that pulls air thru the holleys, compressed by the turbos and sent to the intercooler. Can I bolt this intercooler to an EFI intake utilizing fuel rails etc? Or, do I need a throttle body under the intercooler or? If this is the case, how do you plumb the air thru the intercoolers..hmmmmm, any tips or pictures.
    Thanks!
  8. #21
    Nov 2011
    Default carb box
    Maybe I should just get a carb box, anyone have one for sale? There seems to be very limited manufacturers on "Google" unless I am searching for the wrong stuff.
  9. #22
    Mesa, AZ
    I replaced my steering cable last summer. It was 16' Ill check later today. Might even have the numbers still on it.
    Rack & Pinion.
    Takin it home
  10. #23
    Default Hi Tech
    Hi Tech has been in Shell Knob, Mo. for sometime now. Their service is still impecable.
  11. #24
    Sep 2011
    Ventura County, CA
    Quote Originally Posted by onalky View Post
    Thanks!
    With EFI, and the turbos you have which have seals in the compressors for draw-thru, you could put the throttle body in either location. If you put the throttle body on the manifold, you could get into a compressor surge situation, unless you put in a blow off valve. For simplicity, I would probably put them at the turbo inlets.
    Michael
  12. #25
    Nov 2011
    Default Progress!
    Sure is nice to have someone else working on this project. We are using some old steel ring templates made 20 years ago for double drilling a bowl.
    Learning tap and die is a pretty handy skill too! This is the most fun because it involves working with my son! He just thought he was learning a lot in shop class!
    It is important for him to understand just how many hours it really takes to build anything...
ID:	154123   Click image for larger version.
ID:	154124   Click image for larger version.
ID:	154125   Click image for larger version.
ID:	154126   Click image for larger version.
  13. #26
    Douglas, MA
    Quote Originally Posted by Michael1 View Post
    Michael
    My uncle ran a pretty similar PFM kit for like 20 years and recently went to EFI. He located the throttle body (s) on the carb box.
  14. #27
    Senior Member FormulaZR's Avatar
    Jul 2010
    Nice boat...
    What year is it? And what part of the country are you in?
    Still need cable lengths? I can get them for you tonight or tomorrow if you need.
    If it flies, floats, or fornicates you are bound to have trouble with it.
