My EFI twin turbo build - Page 4
Page 4 of 4 FirstFirst 1234
Results 43 to 46 of 46
  1. #43
    okie, lake Texoma
    are you data logging all of the running its doing? even if it doesn't plane, data log that so you can go back and make changes to the tune in the areas where the issues are occurring. Post up your data logs, this could be a good little thread with some real life info on tuning efi. Have you ensured all your constants are set correctly? have you verified the timing on a timing light with what the PCM is saying it is? Start with the basics, verify timing, verify all your constants are correct, now that you have it starting and idling properly, will it free rev? can you rev it or does it stumble real bad? if so, that needs to be changed before you should try actually accelerating. Also, make your timing a constant value and not a full customized table. have idle be low, in the 10-12 range and everything above idle should be 23-25 degrees, just block the whole thing out (kinda like a locked dist would do) this will give you a safe constant setting so you can focus on the fuel table. you should be in 100% open loop and slowly beginning to modify the VE table based on your data logs and how the engine is responding in relation to what you are seeing on the wideband. don't immediately jump to trying to drive the boat or WOT. go slow, as soon as it stumbles back out of it, shut it off and check your datalog to make the necessary changes, then retry. Tuning EFI is a time intensive process, especially if its your first time, and you want to ensure your first time tuning doesn't end in disaster. Be patient! One change at a time, and datalog EVERYTHING.
    Andrew
    Lol, Yeah or put one of these on there then go straight out & enjoy your boat!
    130.7mph in about 7sec , from an idle.
    http://www.youtube.com/watch?v=bbrazVxN1X0
    Racing is who gets there first, not who gets there on schedule.
    H8-2-W8
    Chandler, AZ
    Hass, I dont know where that will bolt on to my intake Andrew. I did not get into any data logging yet. I was fighting the rain over the weekend. Boat got idled out, checked everything and went to slowly acc. It would just fall on its face. Timing is set at 0 under 400 rpm to start, 17 from 800-1500 rpm, and 28 degrees, with pulling it down to 24 under boost. I will change to a "lockout" table. I will get some data logging hopefully next week as work is crazy right now. As for free rev, it free revs well, just a little fat. We had the laptop hooked up the whole time to watch everything on the fly.
    Dan
  4. #45
    Chico, Ca
    Even with someone watching, you need to be logging. Data is everything when it come to tuning. And it's impossible for the person, or even persons, to see everything that is going on. I do the majority of larger changes when the engine is offline and I can sit down and just look at the datalog. did you verify the timing? It's extremely important that the value the PCM says its at is in fact the value it's at. I sense you did verify, since you mentioned you set idle to 0, which is an easy value to verify the timing obviously. Typically I like to check multiple values just to be safe. So 0 then 15 then maybe 25 and all you do is verify the programmed value is what's read on the timing light. Starting off fat isn't the worst thing, but I find people like to start off REALLY fat and it'll make that engine completely fall on its face and sputter really badly, especially on light throttle application. Also, remember that your engine is very low static compression so if it's not in boost, even if you saw 20:1 AFR, you won't hurt anything at all at low rpm and no boost. one last thing, make sure you turn all added compensations off. For instance Acceleration enrichment, turn it off as its a feature that can really screw up numbers in your VE table as you try to tune. It's a feature that should be turned on only after you have your VE table tuned as well as you can. Then you can add AE to enhance your drivability.
    Andrew
  5. #46
    okie, lake Texoma
    Quote Originally Posted by 79centurion View Post
    Dan
    Hey Dan, you have a really nice setup there. With a little perseverance you will get it handled and it will be a great runner and make great power. I just had to point out one of the inadequacies of efi. Just like Andrew knew that I would have problems logging rpms with a mag I knew that there would be a huge hill to climb initially to setup the efi with a proper tune. Be careful, go slowly and sneak up on the tune so you dont blow the thing up while trying to get it right. Mind the boost guage and start off real low on boost and dont expect it to do exactly what you think it will till youve verified that you have control. With a turbochaged engine you can make eight really expensive ash trays out of your pistons or torch the head/block in just a couple seconds of wfo with the tune being off. Good luck, keep us updated , Hass
    H8-2-W8
