Going to dump some money into my engine after a head gasket blew last summer but dont know which way to go. I have plenty of experience building big blocks for automotive but no jet experience. Decided to tear down the block to verify parts that the owner said were there.
Here's what I have now:
'77 Tahiti 18' with I think 12jc with A impeller. not positive on the jet info though
Engine:
460 bored .060
Cast crank and rods fully balanced
Flat top pistons
d3ve-a2a heads
Clay smith cam: 244 int/exh duration @ .050, .570 lift, 108 lobe center
Dual plane intake and 850 cfm Holley dp
Current setup was running 69 mph on gps
Already purchased a tunnel ram and want to run that.
Option one I am looking at is:
4.5" stroke rotating assembly with dished pistons to put it about 10:1
Porting the D3VE heads (have experience doing this already)
**Cam choice I am clueless on. Clay smith says I should not be running a hydraulic cam meaning switch to solid lifter. It would be nice to save money and run my cam I have now.
Option two:
Edelbrock rpm heads
once again Clay Smith says use a solid lifter. They suggested a .258 duration (@.050), .615 lift, 108 lobe center. To me this seems to low of a cam to even really make use of a tunnel ram.
Question is what would be best bang for the buck to get all around better performance and a bit more top speed. Obviously I'd like to do both but that's just not in the budget. Seems to me the stroker would be all around more fun.
LinkBack URL
About LinkBacks
. I can't count all the boats with WAY more motor than me that didn't quite shine after running me...
Ford Performance
