v drive oil
Results 1 to 5 of 5
v drive oil
    Junior Member speedyt's Avatar
    Mar 2012
    Default v drive oil
    could someone please tell me what kind of oil do u run in a vdrive i am a first time flat owner and my vdrive makes a kool winne suund is this lack of oil oit runs great thanxx
    Meridian, Idaho
    Quote Originally Posted by speedyt View Post
    the lucas gear oil works great but is too thick for me, i like torquo 2&4 stroke trans oil. might not be right?
    Senior Member mdsheppie's Avatar
    Jun 2010
    Michigan,The State Of Confusion
    V-drives whine -as for oil 90 weight
    New here Beer:30's Avatar
    Bakersfield, CA
    I use the TORCO RTF, which is 30wt gear lube that is GL6 rated (highest lube rating). It would be perfect for a Vdrive box and you CAN'T hurt it. It's much lighter than conventional gear lube (more throughput power) and makes my drive run cool to the touch after a WOT run. GREAT stuff.
    Originally Posted by gn7 Its amazing any of us can even get back to shore each outing with those old tech POS we use.
    [IMG]MVC-039F.jpg[/IMG]
    JWM
    JWM is offline
    Boat Test GURU JWM's Avatar
    Santa Ana, CA
    speedyt
    I will tell you what I use and why. For a number of years I have used Lubrication Engineers (LE) Gear Oil # 607.
    It does three things extremely well. 1. It does not run away from heat. Keep the V Drive Very Cool while running. 2. It does not emulsify with water. In other words it will separate water from the oil if water comes in contact with the oil. 3. It keeps the bearings coated even after sitting for months without usage.
    I have been testing Lucas gear oil with good results but I have not done any testing on how long the parts will stay coated when not in use.
    I hope this answers your question.
