Gear Choice
Results 1 to 3 of 3
Gear Choice
    Piedmont, OK
    Default Gear Choice
    What gear should you run in a 10* v-drive with a 325lb hydro and 600hp?
    Senior Member 1fastmopar's Avatar
    with out knowing peak rpm or what prop i would say 18% or 22% with out a 2 speed.
    Tony
    Rat Poison #604
    2011 NJBA 8.0 High Points Champion
    Senior Member md-11mike's Avatar
    May 2012
    Thousand Oaks Ca
    Have you seen a dyno sheet on this engine too or is it SWAG on the hp? Lots of people have 600 hp engines that dont do close to 600 if you know what I mean. Also do you already own a good prop for this set up? If so what size. Gear changes and prop changes get to be expensive.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
