Advise
Results 1 to 12 of 12
Advise
    Senior Member Beerguy's Avatar
    Lake Havasu AZ.
    Default Advise
    I bought a 20ft. Campbell recently. It has an LS-6 .30 over. 830 holley, single plain manifold and roller rockers. Has a Casale 500C with 22% od gears, spinning a 13/11 3 blade prop.
    Had it out today and ran it for about an hour, from Windsor launch ramp down to Copper Canyon, by the time I had got back by Crazy Horse, I had used up 1/2 tank of fuel. My tanks are 30 gal each.
    I was only running it at about 2600 rpm for most of the time.
    Any advise as to changes needed to make this alittle more fuel friendly?
    We will be using the boat for basic cruising around the lake.
    Thanks,
    Larry
    Larry---Keep the diameter of the prop the same but run more pitch.
    Lake Havasu AZ.
    Quote Originally Posted by palhal View Post
    Go to a 14 or 15 pitch?, so run a 13/14, I can buy a 12/15 in town, should I try that one?
    Thanks,
    Larry
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    That seems like allot of over drive - what is your max rpm ?
    [/SIGPIC]
    Lake Havasu AZ.
    Quote Originally Posted by Lucky View Post
    4600 rpm, the boat came with these gears.
    Lake Havasu AZ.
    Gary from Willmington Prop is bringing me out a 13/13 to try next week. Great guy, met him and his wife on one of our neighborhood walks.
    Anything above 12" dia. is ok. You have a heavy boat.
    JWM
    JWM is offline
    Boat Test GURU JWM's Avatar
    Santa Ana, CA
    PALHAL Working with a propeller is a good idea but I think you need to check all your engine systems.
    First check the tune up of your engine. Timing is going to add some milage if it's not correct. Next check the spark plugs! Do they need to be changed? You can work with the spark plug gap to add some milage. What ignition system do you have?? This could add to your fuel issue. Next thing is the 830 carb on a .030 454 (461). Why so big? You can't use 830CFM of air at 4600 rpm. Step down the carb size and create more torque to push that heavy boat you have!!!
    This is what I would do if I wanted better fuel consumption.
    JW
    UMPBA.ORG sleekcrafter's Avatar
    Blown or wrong PV in carb?
    Lake Havasu AZ.
    Quote Originally Posted by JWM View Post
    JW
    Thank you for your advice. Plugs are new, gaped properly, plugs have a nice choc brown to them. Ignition is a Mercury Thunderbolt system. Timing is set correctly, carb was rebuilt and re jetted, 7 lbs. of fuel pressure, all this done about three weeks ago by Huston Marine in Havasu.(long time Campbell mechanic). Motor runs fantastic, so not sure about the tune-up being the problem. I will re-check the timing and the gap on the plugs.
    What advice do you have as to what prop size you would recommend.
    Thank you
    RIP Dave
    Members only MAXIMUS's Avatar
    Close by
    Quote Originally Posted by sksadie View Post
    Thank you
    Larry Jim has a real nice 4 blade somewhere... It might be the wrong rotation however?
    "How do you tell Jerry and Rayzor apart at the races? ..............Rayzor is wearing deck shoes, sunglasses, white shirt with gold and black stripped epaulets and a Captain's hat........ Jerry has the camera." GN7
    http://www.gn-racing.com/
    http://site.enduro300.com/Home_Page.php
  13. #12
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    Maxi
    Don't you have a 3 blade you want to get rid of? I heard Whiskers didn't like it!
    C
