what would be a good 2 blade prop size for 800ish hp in a 20' cambell tunnel v-drive, th400, unknown gears at this time
thanks, jeremie
thanks, jeremie
Turn left
I would say the one it came with.
Germ, call Ron Braskma (RB Props) or Prime Marine. They could probably get you pretty close the first time around. I have a set of 22's that I want to get rid of, but they might be to small for your application ? Is this that all white cruiser you had at the Avi a few years back ? You making the CP deal ?
not sure on the gears but after 10 rotations of the input shaft the output shaft rotated 23-7/8 turns. at the present time the boat has a 12/15 ss 3 blade on it
Turn left
well i know for sure 1 rotation of the input shaft is 1-1/4 of the out put shaft. i probably got something mixed up when trying to keep count with the 10 revolutions of the input shaft
Turn left
